Help adjusting LED headlights
Question to those that have done the retrofit have you had to adjust your headlight after installing them and if so those with AFS before, did you have to adjust the bolt under the car? I rarely drive at night so I just notice that my light output seem to be aimed lower then before and my cut off line seems to be further left then centered. I have an 08 with factory hid/afs and have the sewell LED headlights(stripped) in place now.
Thanks in advance
Thanks in advance
