Help: Front right wheel makes screeching noise
So the past few days I've noticed that the parking "BRAKE" light has been going on and off randomly on the gauges while driving. I assumed the sensor got messed up and was going to take a look this week. I never use my parking brake.
So this morning I get in the car and fire it up and the parking BRAKE light is on and the tire pressure sensor is also on, I check and no flats, all seem adequately pressurized.
I start pulling forward, immediately I get this sheet metal sounding screeching from the front right wheel. The screeching does get worse with speed and does not depend on brake use or pressure. I only made it half way out of my parking spot then reversed back in and left it for the day. Still is doing it when I got home.
Anyone have any ideas?
2010 IS250 AWD
I am not lowered, only mods are lights
Did do a recent oil change and the stuff ricocheted of the dip pan and sprayed wheel & brakes a bit. I wiped it down as much as possible with such little clearance.
2010 IS250 AWD
So the past few days I've noticed that the parking "BRAKE" ...
2002tii
GX - 1st Gen (2003-2009)
09-29-14 05:36 AM
