'06 IS 350 Nav Screen not responding to touch
Old 07-07-13, 11:13 AM
xsaint53
xsaint53's Avatar
Default '06 IS 350 Nav Screen not responding to touch
First off my car is kept in a garage and is Tungsten Pearl--- I read the black IS's seen to have a greater failure rate of the touch nave screen. Here's my issue. Got in my ar yesterday to do some errands. The "Select Language" screen that pops up every time I start the car pops up. TIS time the touch screen is non-responsive. I have some computer monitor wipes, so I tried using those on the screen, no difference. I saw the thread on here about fixing it yourself. I have ZERO (!!) mechanical aptitude-- other than maybe changing a tire or the most VERY basic vehicle maintenance. The DIY fix that was one here is WAAAY over my head. I never had an issue with the touch screen prior to last night. The side buttons still work, but the screen itself is unresponsive. Are there any other fixes-- like rebooting the system somehow.? I restarted the car several times and still no response. Right now a $1200+ fix is not something I can do. Any suggestions. And the car is way past dealer warranty. Car is in in mint condition, but still it's an '06 with over 125 K on it. Thanks.
Old 07-07-13, 04:40 PM
Evitzee
Evitzee's Avatar
You might try disconnecting the battery for 10 minutes or so to reset the ECU. If that doesn't work you might try ejecting the CD-ROM disc from behind the clock and seeing if it won't reboot. Failing that I see a trip to the dealer because there isn't much else you can do.
Old 07-07-13, 04:52 PM
xsaint53
xsaint53's Avatar
Thanks I'll try disconnecting the battery. I don't know how to ejecy the Cd ROM, but I'll do a little research if disconnecting the battery doesn't work. Thanks for your help.
Old 07-07-13, 05:14 PM
Nikon
Nikon's Avatar
there is a guy on the forum that does the fix for it i remember. you have to send him your nav unit. i'm not sure how much he charges.
Old 07-07-13, 08:49 PM
xsaint53
xsaint53's Avatar
Unhooked the battery and after the system re-boot problem was still there. I'm screwed, $1200, $1500+ is WAAAAY to rich for my blood right now, especially on something that is not essential to keeping the car on the road. And me not having ANY mechanical aptitude makes a DIY completely out of the question.
Old 07-08-13, 11:22 AM
mnym8ker
mnym8ker's Avatar
if the unit displays correctly (not blurred or and back up camera works and buttons on the side chage menu but just actual screen does not respond to touch) then its the digitizer and not any fuses. you will have to buy just the screen you can find on ebay for about 350. there is a thread on the how to DYI ill look for it later and post. yes it is due to heat so try to leave sun roof cracked open and invest in a windsheild sun shade.
Old 07-08-13, 12:54 PM
06isDriver
06isDriver's Avatar
its a piece of cake to just replace the screen. Follow the guide and you can get it done. My screen stopped responding too and I just swapped out the screen for another.....or did I fix that screens wires? I forget, but either way isnt a big deal.
Save yourself the money and try to fix it.....its already broke right? how can you break it more?
Old 07-08-13, 03:01 PM
RoyLPita
RoyLPita's Avatar
I believe it is pot luck regardless of color. I drove a 2008 SGM IS250 w/19k that had the exact same issue.
Old 07-08-13, 06:05 PM
xsaint53
xsaint53's Avatar
Tried disconnecting battery last (Sunday ) night and today. Still not responding. Called Bell Lexus (AZ) they said cost is $2035 installed. WAAAAAAY over my head.
Old 07-08-13, 06:09 PM
xsaint53
xsaint53's Avatar
06 ISDriver.... I am probably the LEAST mechanically inclined person you'll ever meet. Unless it something a 3 year old can do, it's probably over my head. And since I have to take the unit out and there's probably more to it than just snapping a piece of plastic into place, I don't want to destroy my dash and interior doing it-- I'm not the most patient guy in the world.
Old 07-08-13, 06:10 PM
xsaint53
xsaint53's Avatar
mnym8ker, back up cam works fine... screen appears fine.... just won't respond to touch.
Old 07-08-13, 06:11 PM
Uda880
Uda880's Avatar
There's a shop in CA that fixes these things for around $900. Great deal considering how much the dealer charges, even after factoring in shipping.
Old 07-08-13, 06:24 PM
xsaint53
xsaint53's Avatar
Uda, that might be a plan, found the screen part of it online for $280. Not sure how easy it is to just plug in and go. Gotta feeling there's more involved than just snapping a new screen on....
Old 07-08-13, 08:42 PM
Bichon
Super Moderator
Bichon's Avatar
I believe you have to remove the radio and partially disassemble it to replace the screen.
If you are not mechanically or electronically inclined, perhaps a local car audio installer could help with this?
Old 07-08-13, 08:57 PM
koolwip350
koolwip350's Avatar
Same thing happened to me thank god for extended warranty i suggest you pick up the complete Chinese nav unit for about $600 and call it a day plus u get a bigger screen by an inch and plays DVDs can't go wrong with that here is the link to do some research
https://www.clublexus.com/forums/is-...w-picture.html
Quick Reply: '06 IS 350 Nav Screen not responding to touch
