Seafoam
Seafoam
I have a 2008 is250, just came up on 60k I know my plugs are due but before doing that I want to run seafoam through the intake (vacuume line). Has anyone used seafoam? I've used it before in previous cars and it works real great in cleaning carbon, I have yet to experience the carbon build up problem with these cars (my check engine light hasn't come on but I have felt wired idling once or twice) do you think I should use seafoam?
Yup heres a hand ful of threads that can be found with the search function
https://www.clublexus.com/forums/is-...treatment.html
https://www.clublexus.com/forums/can...t-success.html
https://www.clublexus.com/forums/is-...-or-water.html
Yeah search is your friend.. I use seafoam with EVERY oil change.. i like to put a 1/4 in with the fresh oil.. 1/4 in the vacuum lines and the rest in the gas tank with a full tank of gas.. You will instantly see (mpg) and feel (vroom vroom) results
OP I have the same car as you - 08 is250 awd
