Leaking CV Joint and Thump Noise
My 2006 IS250 (RWD) rear driver side cv joint is leaking grease where the axle joins the hub (the boot it not torn). Whenever I drive over a bump or a dip I hear a thump noise. If I drive slow over the bump or dip I will not hear the noise. Would a bad cv joint cause a thump noise? I plan on getting the cv joint replaced but I also would like to know if maybe the noise could be caused by a bad shock. Just trying to isolate the problem. Thanks for the help.
