Check System Light Still On
I already set the tires pressure to 37 at the front ,and 40 at the rear after the light pop up. But my light is still on, what can i do with it? Do i need to reset something? Or the light will be go off automatically?
No you don't if your low on air as soon put air back in it goes off rite there. I never had to drive no 50miles. My guess is a bad tpms which one well that gonna be a guessing game. One more note I hope you didn't switch to your secondary sensor on the display setup. Cause then your tmps will light up and stay on. Read your owner manual.
go to the buttons on the left side of the steering column that look like - o - Now cycle through the menu with the - buttons until you find the option for TPMS it will say main and 2nd. Now press the O to select 2nd then press and this told hold it to select the main. Hold it for about 8 seconds or so and you should see the information center on the cluster go blank. That should reset the system and hopefully take care of your issue.
