Carbon fiber vinyl
Carbon fiber vinyl
im going to rewrap my interior trims, but does anyone know how to remove the vinyl correctly? and how to remove the previous vinyl's remaining glue on trim? . thank you
Auto Detailing Master
Vinyl typically peels off and leaves very little residue behind (unless it has been on there forever). Either way, I would start by heating up the surface slightly and then slowly start to peel from one edge.
If you see that there is excessive residue left over, an adhesive remover such as 3M Adhesive Remover would do the trick.
It really depends on the quality of vinyl you initially used. I just had to wrap a customers trunk and removing his old CF vinyl was a nightmare. So much freakin glue residue!
Where in SoCal are you? I can help you wrap it if you like. I've done a lot of other member's trim pieces.
PYSpeed.com
Club Lexus Vendor Marketplace
24
07-25-13 04:10 PM
