Hankook tires
Hankook tires
Hi everyone ,
I'm getting a littl camber wear and was wondering if I can rotate tires left and right? I can't do front rear because I'm staggered.
Please correct me of I'm wrong , but I think it's doable because these are rotational tires right ?
Thanks ~~
Thanks ~~
Not necessarily. You should judge by the tread wear. Any balding is bad obviously. You'll have to flip them. Meaning, unmount rear driver and remount to rear passenger.
IE:
1-2
3-4
to
2-1
4-3
IE:
1-2
3-4
to
2-1
4-3
thanks guys!
i thought what they had to do was instead of doing front left to front right, and rear left to rear right, the tires would just stay as where they are but flip the tires inside out (so left side of tires become the right side of the tiers)...?
Fire Slayer
You're having this problem because of negative camber due to being lowered. A camber kit is truly designed to correct that or add adjustability. I'm currently running the Megan rear camber kit. There's the SPC ball joints for the front or the Megan upper A arms. Look them up and vendors on CL sell them also. Depends on how aggressive your wheels are is where you can run into some problems.
Wish I could get 30K out of my tires. Here are mine after about 10K with about 500 track miles. The V12's don't seem to take punishment to well. Good street tires but wouldn't call them high performance by any means. The tread just seems to rip off. Fronts were even worse and I had to replace them already.
