Grille Help
More information would help. What type of grille did you get shipped? An F-Sport type front grille?
If so, not sure what "pins" you are referring to, but the install is a simple. All you do is remove the old grille and replace with the new grille and use the same existing screws.
Good luck.
Good luck.
Good luck.
Good luck.
