Sunroof rattle FIXED with pics
Old 08-27-13, 04:27 PM
rkspec
rkspec's Avatar
Default Sunroof rattle FIXED with pics
So after reading many threads and searching the interweb i'm surprised i didnt come across this fix.
Slide open your shade and there is a plastic guard in between the shade and the glass.
[IMG][/IMG]
Check to see if there is movement, i tapped it in the middle and sure enough the exact same noise. I can see by the passenger corner (there is a pivot joint) it felt loose and the movement was coming from there. Grabbed a napkin from the glove compartment and stuffed it in there to stop the movement and it worked!
I'm gonna cut some wooden shims and wedge it in where the napkin is rite now. That plastic piece doesn’t move and the wedge wont interfere with the operation of the roof.
and3re (06-12-23)
Old 08-27-13, 05:07 PM
docambriz
docambriz's Avatar
Good stuff that's been driving me crazy.
Old 08-27-13, 06:43 PM
WeisISF
WeisISF's Avatar
thats pretty sweet. i never use the sunroof tho so i never hear the "rattle"
Old 08-27-13, 07:15 PM
draketodd
draketodd's Avatar
Ahhh thanks OP thought I was just going to have to deal with the rattle. Going outside to do this now!
Old 08-28-13, 09:18 AM
rkspec
rkspec's Avatar
so was that the culprit?
Old 08-28-13, 11:33 AM
reyoasian
reyoasian's Avatar
YESSS!!! thank you!
Old 09-09-13, 09:54 AM
Chekmi21
Chekmi21's Avatar
God I hope this is the answer. I'm going to try it this afternoon!
Old 03-22-15, 01:13 AM
is250fsprt
is250fsprt's Avatar
Is there a permanent solution for this fix?
Old 04-11-16, 01:24 PM
supraman6
supraman6's Avatar
Perfectly fixes the issue for me too. It's the drip rail. HOWEVER paper towels wedged in my sunroof is a less than IDEAL solution. Anything else come up? think replacing this part will solve the issue, perhaps the tabs that slide on the aluminium rail have worn down just a little causing the rattling?
http://www.lexuspartsnow.com/parts/l...214-63010.html
Jeff
Old 04-11-16, 05:43 PM
Icy350
Icy350's Avatar
I would use one of those stress relieving *****, more durable they paper, and they don't absorb water either
Old 04-11-16, 05:48 PM
supraman6
supraman6's Avatar
I was thinking of something similar, it needs to be able to easily side along the aluminum rail though. Like a little piece of fabric but with some thickness.
Jeff
Old 04-27-16, 11:39 AM
trdblackis
trdblackis's Avatar
try using a piece of rubber silicone
Old 04-27-16, 07:58 PM
ALtin107
ALtin107's Avatar
Nice and easy fix
gs350lex
08-02-20 02:16 PM
monet33
06-02-20 10:30 AM
Losiracer2
10-14-17 05:40 PM
ssmoked
RC F (2015-present)
10-13-16 02:30 PM
e-man
07-20-09 09:45 PM
Quick Reply: Sunroof rattle FIXED with pics
