Customized D2280 Lexus Menus
I like your GUI theme very much. I have a question about the version of D2280 you are using. Yours shows an "Internet" icon where mine has "Othello" which is a useless game. Did you add that option, or did it come with that? The radio I purchased was supposed to have internet browsing capabilities according to the ad on Alibaba, but when it arrived, it did not have that, although the documentation in the box shows it does.
Would you mind posting your D2280 folder or PM me where I can get that version. I am very interested in playing around with it to see if I can get the browsing to work. I purchased a compatible USB modem. I just need to figure out how to make it work.
Ok so if I want to change the boot logo all I do is download that pic rename it to logo.bmp and throw anywhere on the SD card? then plug it and voila? or do I gotta open the SD card on the unit and move it to internal memory?
d2280 folder inside statistore..
for your safety copy over the d2280 folder to a "backup" folder on your sd card.
Now instead of deleting something simply rename it. For example game.exe -> game.exe.BAK
If something goes wrong, delete the one you copied over and remove "BAK" from the original backed up file
hope this helps
thanks
Cisco
hope this helps
thanks
Cisco
