Navigation screen black! Help!!!!
Old 12-13-13, 02:53 PM
Nsteezyy
Nsteezyy's Avatar
Well my car started finally. And my nav doesn't work anymore... fml.
So im just gonna pick up a junkyard nav, and see if that works...
Old 12-13-13, 04:33 PM
Gville350
Gville350's Avatar
^Oh crap! Luckily I've got a friendly local Lexus salvage yard owner that is willing to help me out; he said he would help me by swapping out my NAV unit with his good one...and go from there.
Old 02-08-17, 07:23 PM
Maria2128
Maria2128's Avatar
Default Navigation screen when black...
Originally Posted by Gville350
Very interesting! I'll PM you for more details about this, but I had the EXACT SAME issues as you had earlier described, including the power comsumption screen. I only started having this issue when the battery in my car came near end of life; still had 385 CCAs though, but I replaced the battery with a new one and still have NO NAV.
Where'd you do to have the charging system checked out?
hi. My navigation when black and not sure what to do. Do you know we're the fuses are of the navigation so I can check them. Please help......???
Old 02-08-17, 07:31 PM
Maria2128
Maria2128's Avatar
Default My navigation is not working and went black
Originally Posted by Nsteezyy
Hey guys, my navigation screen just died out on me... I have no idea what happened.
I've searched around and only 1 person experienced this problem and it fixed by itself.
The radio and clock both work but the navigation and all the buttons on the unit doesn't work..
It worked before but it was strange, it kept showing this power consumption screen and had vertical lines moving across.
My A/C is blasting and I cant turn it off! ITS COLD AS *****.
If you guys have any ideas it would help!
Thanks!
Someone said it might be the battery or alternator but my battery is fine, I don't know how to check my alternator..
hello so my it just happen to me. My navigation turn black and not turning back on. We're are the fuses of the navigation? Can you please help......???
VhernandeZ (09-27-21)
Old 02-09-17, 07:05 AM
rijn
rijn's Avatar
This guy is building me a Nav to Non-Nav wiring harness. This will allow me to switch over two a double din radio using the Scosche LS2151B dash kit.
http://www.ebay.com/itm/LEXUS-IS250-...-/251052866099
http://www.scosche.com/ls2151b
Old 02-09-17, 07:16 AM
mindcrime
mindcrime's Avatar
disconnect the negative battery terminal or fuses 10a and 25a to reset PCM. wait 15 minutes and reconnect then try and see if that works.
Old 02-09-17, 07:42 AM
Maria2128
Maria2128's Avatar
Default Ok let me check
ok let me check and I'll keep you posted. Thanks for your help....
Old 02-09-17, 07:44 AM
Maria2128
Maria2128's Avatar
Default Thanks
I'm going to try the below first and keep u posted. Thank you for your help
Old 02-09-17, 06:38 PM
Maria2128
Maria2128's Avatar
it didn't work...... please help..... :-(
Old 02-09-17, 06:39 PM
Maria2128
Maria2128's Avatar
Default It didn't work.....
We tried it and it didn't work. Please help..... :-(
Old 02-09-17, 07:00 PM
whitebeast
whitebeast's Avatar
The problem you have is not the Fuses. Black screen become very popular now and the problem come from the display driver. Many thread discus about this matter already and like i stated in other thread as well.
YOU NEED TO REPLACE THE BOARD OR REBAL THE BGA TO MAKE IT WORKS AGAIN!!!
Good Luck!!!
The following 2 users liked this post by whitebeast:
AirRideFan (10-05-21), ISFAM (05-03-17)
Old 02-09-17, 07:04 PM
whitebeast
whitebeast's Avatar
Well. if your radio is working fine while your NAV is blacked out. 100% is display driver board is bad.
ISFAM (05-03-17)
Old 03-02-17, 04:01 AM
sergeblr
sergeblr's Avatar
Little thread up. Sorry for my english.
IS250 2006 with nav
Have the same issue few days ago:
At the beginning my nav restarting while driving (show lexus logo and boots quickly in 1-2 secs), sometimes screen is freezing and buttons around screen (audio, climate, auto etc.) not responding. Radio, CD and buttons on wheel works good.
Today nav completely dead: screen and buttons not working, only radio buttons, cd music.
From this thread i read that it is PCB power board problem. Have any experience that replacing it solved this problem? And this is that board? (Link below)
Link: https://www.aliexpress.com/item/Top-...308.0.0.uyp6ow
Thanks for help
Old 03-02-17, 07:45 PM
whitebeast
whitebeast's Avatar
The board you are looking at is for LCD (which is less change leading to the problem you have). The Board you should look for is called display driver board which is much more expensive. A few Members here success by replaced it.
Here it is:
https://www.aliexpress.com/item/Free...08.4.27.H0OKHe
Good luck !!!!
Old 03-08-17, 11:56 AM
sergeblr
sergeblr's Avatar
Here it is:
Good luck !!!!
Thank you for help and link. Seller from your link told me that PCB boards is sold out.
Found other sellers on ali, most of them give reply "out of stock" (but why they updating this lot??)
Few sellers, who confirmed, have only Board code: 462651-0012 (2/2), and on other side: 99370-00357, but my board have code: 462651-0012 (1/2).
Compared by photo all other components - the same. But what this digit (x/2) mean? And will (2/2) board will work instead broken (1/2)?
May be other members, who replaced board from ali or opuradio have photos of brokend and new boards?
Quick Reply: Navigation screen black! Help!!!!
