Maintenance question for our cars
Hi all, I am hitting the schedule maintenance that will include the following:
Replace Automatic Transmission Fluid
Replace Brake Fluid
Replace Front Differential Fluid
Replace Iridium Spark Plugs
Replace Rear Differential Fluid
Replace Super Long Life Coolant
Of course there are more but these are the key ones that I do not know how to DIY on an IS250 (can it easily be done DIY or should this just be given to the dealership)?
I am buying parts from Sewell today and wanted to know how much of each fluid I will need (if any at all). I am buying 6 spark plugs since we have a 6-cylinder engine.
What about the other fluids/coolant, I read that some of them are not needed (I think transmission fluid was the one), and what is the 'super long life coolant' for?
What about gaskets? I would like to DIY and want to know how much of each to buy.
TIA!
Replace Brake Fluid
TIA!
transmission is sealed, you cant replace fluid yourself. Dealers have a special machine to pump fluid out.
brake fluid - manual indicates every 30k miles, not super important, bought regular DOT3 from autozone. Use standard brake bleeding procedure.
differential fluid - manual doesnt state you have to do this but I did mine at 52k doing other things since its so ridiculously easy to change, bought 2qt of valvoline synthetic from autozone only need 1.5qt when I did my rear. Yours is AWD to have front and rear diff? Diff would need fill and drain port crush washers for each diff
spark plugs - manual says 60k miles, bought from sewell
long life coolant - manual says this lasts for 100k miles. Would recommend using the toyota pink coolant or Zerex Asian Coolant (similar formulation and cheaper). Zerex Asian Coolant is only at NAPA and Oreily I believe.
How many bottles of brake fluid should I buy per change (2?).
Yes, I have an AWD so I need ~2L for both front [0.74qt] and rear [1.1qt] (2 bottles of the differential fluid) from Sewell with some left over after the change.
Yes, spark plugs will be purchased, a total of 6 for our engines.
I am going to buy the coolant from Sewell, I assume one jug will be enough even though the coolant needs to be refilled approximately 10 qt (since we can dilute the formula, correct, or do I need to buy two jugs)?
Edit - for the gaskets, I do not see any 'front' differential ones, only rear - is this normal? Is one enough or should I be getting more? What about the oil drain plug?
http://is.sewellparts.com/accessorie...2008/1903.html
just buy the big 32oz bottle of fluid of DOT3 at a local place, its cheap
synthetic diff/gear oil might be better, it was a heck of a lot cheaper than the OEM diff oil. $8/qt i think from autozone
toyota coolant is pre mixed so you have to buy the full amount. It's pricey but, Shouldnt have to change this until 100k.
front diff might have the same plugs as the rear. Not sure
for the diff change make sure you open the fill port first, then drain plug. Because if for whatever reason you cant open the fill port but you drained first....UH OH. Theres a good DIY spark plug guide also on this forum.
yea its at the dealer but pretty pricey. I put some of this in my moms LX:
http://www.valvoline.com/products/br...antifreeze/105
http://www.valvoline.com/pdf/zerex_asian_vehicle.pdf
its also pink like the OEM one. When you look at the formulation its very similar to the Toyota one being silicate, borate, amine, nitrate free
