Car just started up flashing VSC, PS dead , can't shift trans and abs light on.
Old 10-10-13, 07:13 PM
Patsum
Patsum's Avatar
Default Car just started up flashing VSC, PS dead , can't shift trans and abs light on.
06 IS350
I just started my car up and the VSC and stability lights were flashing and the ABS light on solid, a PS light on and the wheel would not turn at all and the car would not shift into any gear out of park at all. Car revved freely.
My only thought is the battery is dying badly, but the car started up right away?
Any ideas?
160,000
has driven great before this. always
Old 10-10-13, 07:37 PM
Patsum
Patsum's Avatar
For christ sake.
If anyone else has this same issue.
The fix is simple....
It is a blown fuse. it is under the driver's side under a small white cover. Center row, second fuse from the front. There is a diagram inside the cover, the fuse is ECU-IG LH, it's a 10A fuse.
Replace it and the problem is gone.
A whopping hour of pure panic that caused me...
Old 10-10-13, 07:45 PM
FrictionSc
FrictionSc's Avatar
Thanks for the info.
Old 10-10-13, 09:54 PM
Turbyturbo
Turbyturbo's Avatar
Why would the fuse blow?
Old 10-10-13, 09:58 PM
Turbyturbo
Turbyturbo's Avatar
Hi. Why would the fuse blow? Did you change the battery?
-Tony
Old 10-10-13, 10:06 PM
Patsum
Patsum's Avatar
changed out my rearview mirror the day before to a 2009+ mirror while the car was playing radio and then turned the car off for a day and didn't connect the events until today.
damn near broke/cracked my windshield installing a new rear mirror by the way.
Androu
RX - 1st Gen (1999-2003)
08-21-18 09:23 PM
Vols4life
GX - 1st Gen (2003-2009)
11-14-17 10:03 PM
czr73
10-23-16 03:31 PM
gxman1
06-27-14 07:53 AM
boostftw
IS F (2008-2014)
01-11-12 11:29 AM
Quick Reply: Car just started up flashing VSC, PS dead , can't shift trans and abs light on.
