Cam gear recall released!
Old 01-01-14, 03:21 PM
  #316
4TehNguyen
4TehNguyen's Avatar
Originally Posted by Uber350
Anyone notice that the 2014, or maybe it happened before 2014, but paddle shift mode allows you to select the gear as opposed to limiting the gear. On my 09, I pick the highest gear it can shift to with the paddles, in the 14, the gear I chose was the gear it stayed in, it wouldn't down shift.
it happened before 14 but cant remember the year. Change for the better, that was incredibly annoying on the 06
Old 01-06-14, 07:28 AM
  #317
Tarrant64
Tarrant64's Avatar
Just dropped mine off for the recall. They stated they will have it through most of the day. Got a loaner, es 300h. Miss my is350 already. The 300h is quote and certainly luxury feel but an absolute boat to drive.
Also was experiencing a popping noise behind the head unit and hope they resolve that as well. Happens a lot and becoming annoying and embarrassing. Something plastic is flexing making a horrible noise.
Old 01-06-14, 02:08 PM
  #318
Tarrant64
Tarrant64's Avatar
Me again, got my car back. Dropped it off around 7:30 this morning, they were done by 3. Idle is a little rough, car shifts a little weird, but I'll give it a couple days and see what happens. I'm a little thrown because I was in an ES300h and it was a little too smooth for me.
Also got my oil changed as well and tires rotated ($140). Overall, happy with the service. I believe the total cost for the recall covered under warranty was in the neighborhood of $1,350. Have to love warranties.
Unfortunately they weren't able to reproduce the popping noise behind my head unit so I'll need to see if I can do that myself. It's pretty consistent so I was a little surprised they weren't able to drive it around to hear it.
Old 01-08-14, 09:55 AM
  #319
Pivo154
Pivo154's Avatar
tarant what do you mean by the idle is rough? I never noticed this before but I got my car back from the actuator recall & as soon as I started the engine I was idling at 2k... is this normal? It felt like someone had their foot on the gas just enough to be at 2k ....
Old 01-09-14, 08:12 AM
  #320
Tarrant64
Tarrant64's Avatar
I was idling pretty high and it may be due to the battery reset that was done. I figured I would give it a few days but I don't think it has dropped much below the 1k rpm since I got it back. It was near if not at 2k when I got it back.
I don't think it's a problem though and will report back over the weekend. It's just not smooth right now and I have conflicting results because it has been below 5 degrees here recently and it runs rough in the winter. I don't blame a car for idling a little high when the wind chill hits -30.
I did sit in my garage after the drive home with the engine on and it seemed ok. I had to reprogram all my radio presets so gave the car a chance to warm up (yes was still cold after drive home). Thinking back on it the idle didn't bother me as much as it did earlier this week so it's either adjusting or likes the fact the high will be 28 today.
Old 01-10-14, 04:04 PM
  #321
stlgrym3
stlgrym3's Avatar
i schedule to bring my car in next week. i'm kind of hesitate to do so, my car is running without any issues, smooth idling, good mpg (consistently in 24 -25 range mixed driving). i'm hearing there will be learning curve for ECU after the recall job, during which the car would feel weird and gets bad gas mileage, it needs to "re-learn" your driving habit again. how long would this "learning curve" be? a week? 500 miles? or more?
Old 01-10-14, 06:44 PM
  #322
Tarrant64
Tarrant64's Avatar
Driving is much better for me now. Idling has smoothed out. Been about 4 days.
Noticing poor gas mileage though, only 16.2mpg. Had a full tank courtesy of Lexus and about 120 miles today, pretty much half tank gone. This has happened once before after a maintenance, took about 2 tanks to get back up to 19-22mpg. No big deal there.
Old 01-11-14, 12:51 PM
  #323
P128sniper
P128sniper's Avatar
sorry for sounding like a complete noob but does it matter where u bought the car from to do the recall. no matter where you buy it from u can take it to any lexus dealer and they will fix? planning to buy a 350 soon from dealer but not sure if itll be lexus dealer or not?
Old 01-11-14, 03:51 PM
  #324
darkdream
darkdream's Avatar
Yes. It does not matter where you take it. Corporate compensates the dealership for the work done. The only reason I would assume they may not change it if a car was declared totaled.
Old 01-11-14, 04:29 PM
  #325
revhappy
revhappy's Avatar
Took mine in the other day, vacuumed the inside, washed the outside, filled it up with gas (brought it on empty), and let me know the waterpump has a leak on it and gave me a 2014 ES300H as a loaner for 2 days. My IS350 still had paper plates from a Ford dealership I got it from used last month.
Old 01-13-14, 02:55 PM
  #326
ocean3737
ocean3737's Avatar
Does dealer charge for checking this issue on IS250, if it's out of warranty?
Old 01-13-14, 03:49 PM
  #327
nosurprise
nosurprise's Avatar
The IS 250 is not part of this recall, so yes.
Old 01-13-14, 03:57 PM
  #328
ocean3737
ocean3737's Avatar
That kinda sucks... I thought 250 had some thing similar... within 9 years..
Old 01-15-14, 07:52 PM
  #329
lz4004
lz4004's Avatar
Default No parts yet
Originally Posted by Gville350
Funny, I go into my local Greenville, SC dealership today and assume I'll be setup with an appointment later this coming week; but they say they have yet to receive any parts to perform this recall. Grrrrrrr! On top of that, I tried asking one of the "service techs" to explain to me why the fix for the TSIB is to replace the actual cam gears and the recall is only to fix/replace the cam bolts. Blah blah blah, it's how they were installed at the factory....BS BS BS.
Anyhow, since their appears be at least one knowledgeable Lexus tech on here I'll ask this question here too.
Why is the fix for the TSIB is to replace the actual cam gear and the recall is only to fix/replace the cam bolts?
Curious to see what ideas we have in regards to this; my '06 350 has experienced the cam rattle about 10 times since I've owned it in 4/1/11.
Thanks!
It`s now Jan 2014. I just made an appointment FOR MY 08 GS350 at my Ct. dealer for the cam
recall. NO PARTS YET. They said 60 cars ahead of me.??.......
Old 01-18-14, 07:29 PM
  #330
Passat774
Passat774's Avatar
Walked into my dealership Charles Barker Lexus on Thursday and said he could take the car on the spot!! I returned on Friday. Service advisor hooked me up with a 2014 GS 350 AWD. Car is fixed and running nicely.
Thanks for the help!!
Quick Reply: Cam gear recall released!
