Cam gear recall released!
Old 10-13-13, 08:01 AM
  #46
jamespoco
jamespoco's Avatar
=) BOUT TIME! I was sick hearing it at drive thrus lol
Old 10-13-13, 10:18 AM
  #47
WhatYaGot
WhatYaGot's Avatar
Any suggestions while they are working in that area of the engine to get done as a preventative measure? I'm sure labor will be a lot less. I'm at 151,000 miles.
Old 10-13-13, 01:35 PM
  #48
smokyis350
smokyis350's Avatar
If we got the cam gear rattle TSIB, do we still have to do this recall?
Old 10-13-13, 03:45 PM
  #49
Gville350
Gville350's Avatar
It's up to you really; but if you had the "updated" cam gears installed already, those will more than likely be what they will be installing for the recall.
Old 10-13-13, 06:50 PM
  #50
GSKaplan
GSKaplan's Avatar
If you had it done previously Lexus is still recommending it be performed. They offer reimbursement in some cases, but only AFTER the RECALL version is performed. As far as I can see the cam gear part numbers from the TSIB and the RECALL are the same....So did they update the gears again? Its really not clear because in the past any revisions to a part constitute a change in the part number.
My opinion (NOT LEXUS - They would say do it anyway) is its to your discretion. But, If you hear a rattle, get it done.
Context from the Owner Letter:
"What if you have previously paid for repairs to your vehicle for this specific condition?
If you have previously paid for repair to your vehicle for this specific condition prior to receiving this letter, please mail a copy of your
repair order, proof-of-payment and proof-of-ownership to the following address for reimbursement consideration:
Lexus Customer Assistance Center L201
19001 South Western Avenue
Torrance, CA 90509
Please note that the dealer must complete the Safety Recall remedy before reimbursement consideration requests can be processed"
Some other questions:
No the oil isn't changed with the repair.
Maintenance you could probably get done at a discount - Spark Plugs, Air filter, Drive Belt.
Old 10-13-13, 10:42 PM
  #51
Toxicxk23
Toxicxk23's Avatar
How long does this repair take? Would I be provided a loaner if it takes a few days?
Old 10-14-13, 06:50 AM
  #52
jamespoco
jamespoco's Avatar
Im getting a loaner tomorrow because its going to take a whole day to perform.
Old 10-14-13, 07:02 AM
  #53
ShawnD
ShawnD's Avatar
Is350 > is250
Old 10-14-13, 08:53 AM
  #54
RangerJoe
RangerJoe's Avatar
I see that the timing chain cover gasket is included in the list of parts used. I was told mine is leaking and they are charging me to have it replaced when while this recall service is being done. I would imagine the timing chain cover has to come off anyway for this recall. Any idea how much overlapping labor is being done between those two services? If I'm getting hosed on this, I'm going to be making another call.
Old 10-14-13, 10:26 AM
  #55
Chuy250
Chuy250's Avatar
Sucks for the IS250 owners and I am one of them. What about the rattle for the IS250's? Mine has 64,xxx miles and started 60,xxx miles to make that noise.
Old 10-14-13, 10:38 AM
  #56
smokyis350
smokyis350's Avatar
Torrance, CA 90509
What reimbursement are we talking about?
Old 10-14-13, 11:56 AM
  #57
panda08
panda08's Avatar
if they do have to take off the timing chain cover gasket as part of the recall, they should not be charging you to reinstall a new one since it has to come off and they have to put one back on. especially if its included in the parts list.
Old 10-14-13, 12:21 PM
  #58
tiny2009
tiny2009's Avatar
Exactly the same issue for me at the moment, have waited for the recall to have a timing cover leak sorted at the same time. Have been told 7ish hours for the recall where the leak was going to take around a day and half? By doing them at the same time it's "saving" me half the labour?
What extra work would be involved for the timing cover to have it's gaskets replaced compared with what's involved with the recall? Seems a little fishy to me...
Old 10-14-13, 12:50 PM
  #59
RangerJoe
RangerJoe's Avatar
I had the timing chain cover replaced a little over a year and a half ago under warranty, and it's leaking again. When I talked to the service adviser this morning, they are going to cover a good portion of the timing chain cover repair. That being said, they are still wanting to charge quite a bit. I don't know what other parts are included in that timing chain cover repair, since you never get a detailed list of what they do.
Old 10-14-13, 01:46 PM
  #60
vapid2323
vapid2323's Avatar
The parts are cheap if thats what your asking, I had mine done and I don't think the parts cost more than 600. Now the labor was over 2500 for mine. I will see if I can find the original work order.
So simply I was told that they basically have to pull the engine out to fix the timing cover and thats where the cost is.
Quick Reply: Cam gear recall released!
