Fog lights replacement
So my fog lights are scuffed up and I don't like the look of them so im trying to convert them to look better and get something diff. Does any one know if this will work. Using the cover plate to fill in the rest of the space on my 06 ISx50. It looks like its the same dimensions and all i will have to do is figure a way to get them mount to the bumper..
http://www.ebay.com/itm/121186812463...84.m1438.l2648
Depends on how "scuffed" they are. If they can be sanded down and polished you may not need new foglights.
Personally if i were you (if your foglights are not able to be saved), I would consider just buying used foglights and fitting projectors in them.I believe thats a different look and looks a lot cleaner.
jvxdriver has a great writeup that i plan on utilizing in the futre for my 2006 IS250
https://www.clublexus.com/forums/lig...g-mini-h1.html
