Premature wear tire shoulder - Michelin Pilot Sport A/S Plus
A couple days ago I got my tires replaced after 25K miles. The inner part of the tires is completely worn out while the outer side of the tire still have about 2.5mm left. The rear tires has 3mm and they were even. I ask for an alignment. The sheet below is what the dealer did
Is there any numbers there should be adjusted to reduce inner wear on the front tires? After the alignment and tire replacement, the car does handle little better.
https://www.clublexus.com/forums/sus...0-duro-hp.html
https://www.clublexus.com/forums/is-...eo-inside.html
and which one of these should I buy to fix the inner tire wear issue ?
http://shopfigs.com/v1/index.php?rou...product_id=197
or
http://shopfigs.com/v1/index.php?rou...product_id=138
I think the link to the second is the one. GEN 2IS IS-F 3GS FRONT LOWER ARM REAR MOUNT #2 POLYURETHANE BUSHING 90 HIGH PERFORMANCE
The picture seems to match those in the other thread -- I'm interested in this as well ... Does anyone know it will affect alignment? I just got an alignment :/
Has anyone found a fix to this? Im over 50k miles on my Lexus IS 350 and am on my 3rd round of tires. The stock dunlop tires that came with my car were the WORST. I had to take them off almost before I reached 25k. The next set I chose were Eagle F1 All seasons. These seemed to last longer than the dunlop & I think I reached around 35k but you could see the wires sticking out on the inner part of the tire. This was only on the front two tires like many of you have mentioned, the rear tires were actually still in decent condition. Currently I am running Hankooks but what can we do to get around the inner tire wear to get more mileage off our tires?
car , is probably the fix. That's what I'm thinking of doing. My camry never had these problems not matter what type of tire.
Hello all,
Took my car in for an oil change today and the tech guy told me my front tires shoulders are almost bald. I was very surprised as these tires are only less than 2.5 years old with less than 35k km. I took a look with him and to my surprise it looks pretty bad. The rears are fine with plenty of tread tho.
![](http://imageshack.us/a/img9/9702/zpqe.jpg)
![](http://imageshack.us/a/img855/7481/wtqh.jpg)
![](http://imageshack.us/a/img11/4944/ctha.jpg/)
![](http://imageshack.us/a/img59/6901/n870.jpg)
Anyone else with these tires have the same issue ?
So I took it to Kal Tire yesterday as instructed by Michellin for a diagnois and safe to say I was no impressed. Not only did they not care about the chunking on the tire, all they did was blame my alignment for the problem. There is no way my alignment can be that off to cause both front tire to be bald on both shoulder AND chunking. All Kal Tire did was try to sell me an unnecessary alignment.
I can't believe MIchellin is not acknowledging this issue. This has gotten to be a safety concern and they are trying to play it off like its nothing.
The reason your Camry does not do this , is because you can rotate the tires, and it does not run the amount of camber that these Is350's run. The edge wear is from the camber and the lack of not being able to rotate the tires.. The chunking though looks like it is a problem of the tire or driving on a lot of gravel. Hope that helps whoever is still looking at this for answers.
Whats the difference between the front lower arm rear mount and FRONT UPPER CONTROL ARM POLYURETHANE BUSHING CAMBER ADJUSTMENT?
or
or
You can also align for slight toe-in...
Let me know how this goes mr. panda. I wonder if it improves handling or performance over bumps. The other posts indicates that it might improve?
With parts and labor, I can almost buy 4 new tires ... if my front tires wears out as good as my rear tires, it would add at most 10K miles; so I would have to change my tires twice to recoup the cost ...
I will write a longer review on the Figs front LCA bushing as I put more mileage on the car. So far, I think it is a worthy upgrade. Though, it is an expensive one.
