IS250 Engine Rattle on Startup
Old 10-30-13, 02:38 PM
lexus-is2
lexus-is2's Avatar
Default IS250 Engine Rattle on Startup
I had a top level engine rebuild 3 years ago to rectify the occasional rattle noise on startup on my IS250. Noise had disppeared but now i think its back. I've heard it twice so far. It's not low on engine oil or anything as I've recently done an oil change.
Has anyone had this rattle fixed and then have it return again? Has anyone left this rattle alone and is it problematic? It does not sound as metallic as before but still concerning and its very occasional and not necessarily on cold start as i've heard it once on warm startup too.
Old 10-30-13, 04:15 PM
drewster12
drewster12's Avatar
I have had the same issue. For the last 2 oil changes, I've used Castrol Synthetic 5w-20 on my 2006 IS250 and it's gone. I've used Mobil 1 before, but the noise comes back when the oil gets old.
Old 10-30-13, 06:22 PM
jdmSW20
jdmSW20's Avatar
that sound could be what this whole recall has been mentioned about in previous threads. i dont think it has anything to do with what type of oil you are using
Old 10-30-13, 06:39 PM
Noeh
Noeh's Avatar
My car has no issues with Mobil 1 /knock on wood
Old 11-03-13, 06:45 PM
Hfahb
Hfahb's Avatar
That's interesting. I just recently purchased my 2012 IS 250 and as the weather is getting cooler I am noticing for about the first minute or two when the engine is cold I'm getting that same type of rattle.. I've been thinking when I take it in for my first oil change I'd like them to check it out. Could be normal but just to be safe.
Out of curiosity, what year is your IS?
Old 11-03-13, 08:19 PM
two2tone
two2tone's Avatar
My IS350 does that too... occasionally...
Old 11-03-13, 08:58 PM
rookieIS
rookieIS's Avatar
its the cam gear rattle that you're having, there's a TSB for IS250
Old 11-04-13, 12:06 PM
showtymers
showtymers's Avatar
im pretty sure this will en dup a recall i dont see why the 250 wasnt included with the recent recall on the actuator recall i pretty sure they used the same bolt on both
RXGS
09-19-21 08:38 PM
terminater
03-19-18 07:53 PM
DixieLex
06-13-17 07:19 AM
Zoinks
03-21-06 03:16 PM
Oivey2000
RX - 1st Gen (1999-2003)
03-14-03 07:47 AM
Quick Reply: IS250 Engine Rattle on Startup
