headlight output not even!!!
Old 10-31-13, 10:12 PM
metaleckz
metaleckz's Avatar
Default headlight output not even!!!
so i just found out that my headlight's light are not even!
is that normal? if not, how do i fix this
Old 11-01-13, 07:35 AM
NYKnick101
NYKnick101's Avatar
they are projectors so if you park in front a wall, you can see where the lines are and then adjust it accordingly
Old 11-01-13, 07:38 AM
sm1ke
sm1ke's Avatar
Just do a headlight adjustment. Its really easy. Lexus has a PDF document of how to adjust them on the web somewhere, just Google it.
Old 11-02-13, 01:53 AM
Nguyen925
Nguyen925's Avatar
If all else fails try using Youtube. That left headlight, if I'm looking at it correctly, is probably blinding a lot of people from their rear view mirrors. Good luck!
Old 11-02-13, 02:04 AM
panda327
panda327's Avatar
They are not supposed to be even. The driver side headlight should be lower to prevent blinding on coming cars. In your case it seems your driver side is way too high
Old 11-02-13, 11:00 AM
edgeucated
edgeucated's Avatar
yep, the cutoff on the driver side is suppose to be set lower. Because of this design, your headlights will never have the exact same output, you can play around with the aim and get it pretty close though
Bryan@Autogeek
Automotive Care & Detailing
10-22-13 10:26 AM
xtremex626
10-16-11 01:38 AM
ortizarn
10-08-09 09:34 AM
vindedreal
GS - 1st Gen (1993-1997)
08-30-08 10:05 AM
flm
03-13-02 09:33 PM
Quick Reply: headlight output not even!!!
