High beam/drl, wire color? Help
Does anyone know what color wire is for the high beam/drl in the fuse box?
I just recently did the fog light mod to turn on the fogs when the driving light is on. So now to eliminate the DRL sense the dealer won't I want to wire the high beam power to the fog light wire switch sense it is free now. So to turn the high beams on I'll just twist the fog light switch on. This I believe will disable the DRL because the power source then will actually be from the fog light switch.
Thanks CL!
Thanks CL!
The dealer should. I bought mine from a private owner, have never spent a dime at the local Lexus dealer. I stopped by and said I needed to adjust one of my Lexus Personal Settings. The guy didn't bat an eye and 2 mins later those hideous DRLs were off.
