How do I use the shifters in my 2007 is250?
Old 11-09-13, 11:17 AM
510to808
510to808's Avatar
so basically there for looks. and if you wanted to shift while driving you shoulda thought about it before you got a automatic lexus! note to self: i wouldn't want a manual lexus unless i won the lotto and got a lfa lol
Old 11-09-13, 12:32 PM
nabbun
nabbun's Avatar
The only times I've used my paddle shifters in my 2007 IS250 AWD were in a few instances when I wanted to show off my Blitz Sonic Power / JoeZ pipe combo and a few times in the Tail of the Dragon when I went with HKS350 years ago. I kept it at most of the time 3 because you didn't have room to get into 4th. A few hairpins is where I brought it down to 1 so I could blast out of them. I think I could count on 1 hand how many times I was able to get it to 4th.
Other than that, our paddle shifters are quite effing useless. You floor it and it'll kick down on it's own. You tell it to upshift with your foot down and it won't until it just before the rev limiter or about 500 rpm before if it's in sport mode. Most of the time, I wondered why even bother adding the cost of incorporating paddle shifters if the car was going to decide for you when it's going to shift anyway. Soooooooooo freaking stupid.
Old 11-10-13, 12:39 AM
viprtwo
viprtwo's Avatar
I actually use them quite a bit. Mainly to downshift when exiting the fwy, before a turn, coasting downhill, or driving on the street and keeping the car revved higher for better control at partial throttle.
It does basically what I usually do in an actual manual transmission car, since I can determine when/if I need anything more than 4th gear.
What I do wish, is that there was a way for the 06 to behave like the 2012, where the car can be in D and the down shift paddle still activates. The 06 requires me to use S mode to enable the paddles.
Old 11-10-13, 03:31 AM
Marcusvdw
Marcusvdw's Avatar
Hi from Belgium ....
Just a little question related to Viprtwo post :
What the difference between the gearbox of 2006-2008 Is and those after...
Those where you can use the paddles even in D ....
Is it a hardware change of can we just flash the ECU to gain this option ???
Marcus (2008 IS 250 )
Old 11-10-13, 07:12 AM
carlos3366
carlos3366's Avatar
They are useless, I shift using the stick shift all the time. In fact, how do I remove the paddles? so I can throw them in the trash.
LisaAnnWil
Performance
11-15-17 02:57 PM
dhirons
05-18-13 02:14 AM
rail27
Performance
05-21-09 10:01 AM
erolmon
09-12-07 08:49 AM
CWIS250AWD
Performance
13
06-23-07 10:10 AM
Quick Reply: How do I use the shifters in my 2007 is250?
