Changing a Flat with pressure sensors
Old 11-11-13, 08:56 AM
ElMatadoro
ElMatadoro's Avatar
Default Changing a Flat with pressure sensors
Hi all,
This being the first car I've owned with the tire pressure sensors, are there any specific things needed to be done if I get a flat and have to buy a new tire?
I'm guessing the sensor on the tires can be reused? Does it have to be reprogrammed?
Appreciate the advice...
Jeff
2011 IS 250
Old 11-11-13, 08:58 AM
pmanliu
pmanliu's Avatar
No reprogramming needed as your sensors are staying with the same car. Nothing special you have to do.
Old 11-11-13, 08:59 AM
4TehNguyen
4TehNguyen's Avatar
sensor is attached to the valve stem of the wheel, when you get a new tire, nothing changes
Old 11-11-13, 09:02 AM
ElMatadoro
ElMatadoro's Avatar
Thanks guys - so just tell the tire spot that the sensor is there and to be careful when removing the tire from rim..
Old 11-11-13, 09:09 AM
RVCAis250
RVCAis250's Avatar
Yep, if they're smart they should remove the tire sensor before removing the tire in order to not damage the tpms. So just make sure they know
Old 11-11-13, 09:53 AM
ElMatadoro
ElMatadoro's Avatar
got it, thanks!!
Old 11-11-13, 04:32 PM
DRivera250
DRivera250's Avatar
you should have no problems. have had my fair share of tire problems, but no problems with tire sensor. If something is broken they can usually rebuild it.
SteveCanyo
HS 250h Model (2010-2012)
10-13-18 06:44 PM
Monique023
05-07-14 06:21 AM
TXFM
02-09-07 06:46 AM
robinzon
GX - 1st Gen (2003-2009)
15
01-20-06 06:09 PM
robinzon
01-18-06 06:29 PM
Quick Reply: Changing a Flat with pressure sensors
