2008 IS250 door actuator motor?
Hi all,
I'm having trouble with my door actuator for my front passenger and two rear doors. Today I attempted to fix one of my rear door. The actuator came out pretty easily and I was able to open up the actuator. But here is where the problem begun. After reading through some useful thread on door actuator DIY I brought 4 of the mabuchi motor hoping it would be the same one as the one in my '08 IS250. Turns out, I was wrong (at least I think I'm wrong).
The motor on the left is the mabuchi and the one on the right is from my is250.
![2008 IS250 door actuator motor?-motor-4-.jpg](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/304708d1461126165t-2008-is250-door-actuator-motor-motor-4-.jpg)
You'll probably notice that the bottom and the shaft at the top are different.
Now my question is, did I brought the right motor but just need to modify it (cut the shaft on the mabuchi to the right shape and somehow fix the bottom)? Or do I need to look for the correct motor? Can anyone direct me to the correct motor?
I also try looking up the number on the Lexus motor (PAN14...) on ebay but came across nothing.
Thanks in advance!
Thanks in advance!
I searched and found this thread here https://www.clublexus.com/forums/is-...-actuator.html. You can contact the OP who did it maybe he will have an answer for you.
