Trunk won't open
My trunk won't open with key nor on trunk or from the inside. Lighter went at same time so I thought it was a fuse. Mechanic changed it and it still won't work. He said he needed 2-3 hrs to figure it out so I left.
What could it be?
What could it be?
Once you have the glove box open, you should see a button on the left side right below where you have to insert the key, the button should be marked "Trunk Opener"
Press the button in so that it's "ON", (If the button is sticking out that means it's "OFF")
I attached an image on my previous post that you can use as a guide.
Thankyou
MR. DRYEYE....soooo...I did what you said and IT WORKED...THANKU, THANKU, THANKU! I have to get tires tomorrow and needed to get in there...I'm so happy
Any suggestions on tires. I was going to get the Michelin pilot A/S 3...
