Body shop ordered wrong headlights. Can they send it back?
So my car was in an accident where my driver side headlight tabs were broken and lens are beat up. My car is a 2011 Lexus IS350 F Sport and around a year ago, I took my 2011 Daytime running light (stripped edition) for the bubbling defect recall and got it replaced with a 2012. My body shop ordered 2011 headlights due to the sense that my car is 2011 so now I am driving around with a yellow strip (2011) and white strip (2012). Do you guys know if my body shop can send the headlight back to Lexus and get the correct one? I already took off the 2011 headlights to prevent scratches from road conditions.
Technically they've not done anything wrong; but if you're a calm, cool customer and can explain the situation to the body shop and even maybe show them the receipts from the dealership for when they replaced your headlamps with the 2012 models...you might just convince them to exchange them.
Honestly, I'm not sure I see why it's your fault. Why isn't it the body shop's obligation to check the parts they are ordering before they order them? Sure, it would have been easier if you pointed it out to them, but I think they have an obligation to verify part numbers, rather than just assume based on the year of the car. What if it were the wheels, and you swapped out one model year for a newer one--or even went after market? You wouldn't just throw up your hands and say "My bad", would you?
It's not even just the LED colour that's different, the headlight actually looks different before they're even on.
The original lights on a 2011 would have a flat black coating inside and a completely clear lens. The newer lights installed have a gloss black coating inside and diffuser ribs on the lens (affectionately referred to as "eyelashes" here on CL).
Any time an updated part is installed on a car you're going to need to be careful if that part is ever going to be replaced in the future. Obviously the body shop just gave the VIN to their Lexus dealership and they sent the light that originally came on the car. It's not wrong per se, but it is wrong for the car now that Lexus had installed newer headlights into the car. There is actually a note in the TSIB from Lexus stating that in the future if the headlights need to be replaced you'll need to order whatever is actually installed on the car and not what came on the car from the factory.
There are 5 versions of the headlights with the LED's. Externally, visually there are 3 versions of the headlights.
IS Sedan / IS C F-Sport part numbers (these are accurate as far as I know, but I haven't personally held all of these part numbers in my hands):
Prefix:
81145- (RH)
81185- (LH)
Suffix:
53540 - Original 2011 Design (Flat Black, Clear Lens)
53541 - Very Early 2012 Design (Gloss Black, Clear Lens)
53542 - Early 2012 Design (Gloss Black, Eyelash Lens)
53543 - 2012-2013 Design (Gloss Black, Eyelash Lens)
53544 - Newest TSB Design (Gloss Black, Eyelash Lens)
Visually the 53542, 53543 and 53544 are all the same, I believe any differences are in the type of materials used either in the coating or the lens.
NOTE
Jeff
Prefix:
81145- (RH)
81185- (LH)
Suffix:
Originally Posted by Lexus TSIB L-SB-0005-12
NOTE
- If the headlight assembly does not have visible paint bubbles and only one headlight needs to
be replaced (for collision damage repairs, etc.), use the part number for the headlight that the
vehicle is currently equipped with. Updated parts are not compatible with prior part numbers.
- If either headlight assembly has visible paint bubbles, replace the headlights in pairs with the
NEW part numbers.
Sedan part numbers (these are accurate as far as I know, but I haven't personally held all of these part numbers in my hands):
Prefix:
81145- (RH)
81185- (LH)
Suffix:
Jeff
Prefix:
81145- (RH)
81185- (LH)
Suffix:
Jeff
So I had the lights replace a few months back and they put in 81185-53671 and 81145-53671, they have no eyelashes and still look like the piano black inside. Did they have different numbers for the convertables? Mine is a 2012 350C that came with eyelashes but not the gloss black
IS F / IS C (without F-Sport):
Prefix:
81145- (RH)
81185- (LH)
Suffix:
53670 - Original 2011 Design (Flat Black, Clear Lens)
53671 - Very Early 2012 Design (Gloss Black, Clear Lens)
53672 - Early 2012 Design (Gloss Black, Eyelash Lens)
53673 - 2012-2013 Design (Gloss Black, Eyelash Lens)
53674 - Newest TSB Design (Gloss Black, Eyelash Lens)
Yes the IS F and IS C have different headlights than the IS Sedan (with the exception of the IS C F-Sport which uses the same headlights as the IS Sedan).
Prefix:
81145- (RH)
81185- (LH)
Suffix:
Prefix:
81145- (RH)
81185- (LH)
Suffix:
