Why do my tires do this on the 250?
incorrect toe even by a couple mm will chew your tires faster than any negative camber will. My fronts have some pretty bad choppyness cause from poor toe. I think toe out in my case.
What is the best front camber kit for the IS and do you still need the FIG LCA bushings?
