IS250 Headlights Out of Focus
My 2006 IS250 headlights (low beams) are both out of focus. The problem began after I attempted to swap out the stock (working) HID bulbs for a new set, of a higher Kelvin rating. Since I swapped them, the focus of the headlights is off and the light output is horrible. I have attached a photo. In this photo, on the driver's side (the focus is off and the lighting looks scattered), the passenger side headlight focus was ok in this photo (before I touched it).
After I had swapped both headlight bulbs and realized how horrible the light output was, I put the stock bulbs back in and realized that the light output was still screwed up. At this point, I assumed that the poor light output is a result of the headlights being out of focus (unless there is some other reason I am unaware of...).
The auto focus doesn't even correct the problem after turning the car off and on.
How can I correct this problem?
snagit
snagit
Uhhhhhhhhh. Headlights don't focus. They aren't like eyeballs... Lol
It's probably poor bulbs... That and you need to back up.... There is a certain distance you are supposed to be at when aiming your headlights and looking at the cutoff...
In the pic, your headlights looks purple ish in that pic.... If you know about the kelvin ratings- the higher the kelvin, the LESS usable light the bulb produces. I'd stick with stock, 5000k, or 6000k.
Ps- headlights only auto level (up/down)
1. Your driver side light looks like your bulb isn't sitting right. I've seen this happen in my friend's IS when he didn't sit the pin which holds the bulb in correctly and the bulb was crooked in the bowl. Needless to say, that bulb didn't last long. Check to make sure all is right.
2. You shouldn't have any "focus" problems. Because you cannot control the distance between the bulb and the lens.
3. You're like a foot and a half from the garage door, that will significantly concentrate (didn't want to say focus) the light into a small area. Try backing up, maybe 25 feet or so from a flat wall on a flat surface and see what it looks like.
I assume you say "auto focus" probably referring to AFS and Auto Leveling. AFS/Auto Level doesn't focus anything, I wish it did, that'd be cool. I couldn't even tell its working most of the time when I turn. But if by chance it was a halogen set up converted with a pnp hid kit, in addition to a new (perhaps not as quality.. ie GARAX, PHILLIPS, OSRAM..ETC..) bulb will produce a bad output. The halogen projectors are not really designed for HID output. Hell, the HID projectors on this car sucks as much.
Thanks Jeff Lange and KennyD, you guys were spot on.
There were a couple of things wrong with my lighting... The scattered, out of focus light emitted from the headlights were a result of two things. One, the bulbs were not perfectly seated into the housing, and two, the hold clasp was not providing the support against the bulbs to keep them in place. After re-seating the bulbs and strategically re-bending the hold clasp, the bulbs were seated snugly into the housing without any play.
Once I realized the problem, I tested both the original OEM bulbs and the aftermarket 6000k bulbs for functionality and confirmed that the temperature of the bulbs was did not change the focus, or the pattern of the light emitted (when the bulbs are seated properly of course).
I was much too close to the garage door to properly adjust the aim height, but I initially just wanted to compare the difference in bulb colors against the garage door, but then I realized I had a lighting focus issue, so I took the pic...
Lastly, I adjusted the AFS position sensor down, to raise the aim height of my low beams and I now have a much better visibility without blinding oncoming motorists. I have a renewed enjoyment for night driving.
AFS position sensor adjustment shown here: https://www.clublexus.com/forums/is-...djustment.html
I was able to adjust the AFS position sensor w/o raising the car up (stock ride height). I just laid on my back, next to the car with a 10mm socket w/ extenstion... took 30 seconds.
Thanks for your help everyone.
Shaneh85
07-22-13 07:18 PM
IAMJAVEDG
12
03-10-09 04:37 AM
