HID low beam flickers randomly. replaced low beam last week
My passenger stock low beam went out few weeks so I decided to buy garax 6k to replace them.
Ever since I replace them, my low beams would flicker when I hit a bump on the road. I checked the connection to the bulb multiple times and it seemed tight. Am I not connecting the low beams correctly to the wire?
TIA
TIA
can't help you out with the placement of the ground connection.. my IS didn't have stock HID's in it.. all I know is that when i installed my xenon depots i had my driver side flickering when hitting bumps and what not.. checked over the whole system and turned out my ground connection was loose
There is a specific way the bulb needs to be seated? I thought it was random because its not like a 9005/9006 bulb where you rotate and it locks into place. The D4s locks by using a pin.
Where is the black cable? All I see connecting to the D4s bulb is the stainless steel connector.
Speedy321
12-07-15 12:07 PM
conekiller
06-06-06 07:24 AM
