Is350 spacers need your help
I'm looking for spacers for 2nd gen is. Could anyone point me in the right direction on what to get or maybe a vendor I want it to be flush and not stick out at all I have coils so I'm low will I have problems rubbing and do I need to raise the car to prevent it?? I have stock 18 inch rims. Thank you!
of course its going to rub especially if you put spacers on the stock wheels and still have the stock 40 series tires. its going to rub all over the place if you are lower than stock. the fender liners, tabs, etc
but i had ichiba spacers and they come with extended studs as well. not too pricey either
I have F-sports springs on stock wheels. My spacers are 15mm in the rear and 20mm in the front. The reason the front is more is because the wheels are more cambered, so the top of the tires are farther in. It will rub if you do a fast U-turn.
grekt
05-16-17 07:26 PM
