Lifting IS 250 with a small floor jack
Old 01-07-14, 08:13 AM
cxc511
cxc511's Avatar
Default Lifting IS 250 with a small floor jack
I have a small 2 ton capacity floor jack that I use to change over snow tires/wheels and the like for all of my vehicles. The jack works well but is designed to only take up one corner of the vehcile at a time.
How are RWD IS owners lifting their vehicles for wheel change over, etc? Are there lift points to take up one corner of the car with a small floor jack? I reviwed the owners manaul on my girlfriend's RWD IS 250 several times and it seemed the only points were in the center of the car to take up the entire front or rear end. I don't have a jack that big and feel more confortable working with one corner of the car lifted at a time.
I was always afraid to take up one corner of the car with my floor jack - even with a hockey puck between the jack and the car. I felt like I was going to damage the uncarriage piece that covers the frame...
Any input is appreciated.
Old 01-07-14, 08:25 AM
minato
minato's Avatar
https://www.clublexus.com/forums/is-...-on-is250.html
post #3, JoeZ has a diagram
also a DIY
https://www.clublexus.com/forums/gs-...he-car-up.html
Old 01-07-14, 06:25 PM
ChiLexus10
ChiLexus10's Avatar
All I know is I used the oem jack to change out a flat and my car
Fell off the jack twice onto the frame and rotor.
Old 01-07-14, 10:36 PM
jgr7
jgr7's Avatar
I bought this low profile AC Delco 1.5 ton floor jack from o'rileys auto parts. http://www.oreillyauto.com/site/c/de...0768&ppt=C0373
I use the jack points for rear at the differential and the front the center point listed in the owners manual. Here are a couple of pics, one up on 4 jack stands and one with the jack in the front and two jack stands.
Attached Thumbnails Lifting IS 250 with a small floor jack-002-800x531-.jpg   Lifting IS 250 with a small floor jack-lowered-car-006-800x531-.jpg
Old 01-07-14, 10:42 PM
jgr7
jgr7's Avatar
Even with the low profile jack now that I am lowered I have to use another floor jack to lift up one side just to get the low jack under to the lift points. Its a pain but I always put jack stands under the car if it is off the ground.
Old 01-08-14, 04:02 PM
todd4566
todd4566's Avatar
Yeah.. this is why I always installed subframe connectors on all my Mustangs (I've had 4).. so I could jack the car easily and feel confident it would never fall. I don't feel very confident jacking up my car at all right now.
Old 01-08-14, 09:29 PM
Litcroco
Litcroco's Avatar
Sorry my question is a little off topic but I wanna ask what kinda jack stand do all of you use or does it matter? The stand that I used have a concave kinda tip and it bents the support position a little and made a crack on sides. So currently when ever I needed the car to be lifted, i would just lift it up and left the jack underneath the car without the stands.
Old 01-08-14, 10:24 PM
jgr7
jgr7's Avatar
Not sure of the brand, two different brands both 2 ton each. If I'm not lifting both ends I will put the stands under the car and just lower to touch the stands but leave the floor jack with the weight. The stands are for jack failure so I just let it touch them.
Old 01-09-14, 09:09 AM
cxc511
cxc511's Avatar
Thanks for the replies. I found the images with the lift points indicated for each corner, but they did not seem to work with my floor jack. I never bothered to pull out the jack from the trunk of the IS, but felt the lift points were perhaps designed specifically for that jack.
There is a local garage nearby that will switch over her wheels for $15, so while I prefer to do this type of thing myself, in this case it seemed easier to use the garage rather than risk damaging the car. Just curious if others had a similar experience.
Old 01-09-14, 10:35 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Try using this. http://shopfigs.com/v1/index.php?rou...product_id=188
Old 01-09-14, 02:38 PM
cxc511
cxc511's Avatar
Originally Posted by Sffd103
Thanks - I will have to look into that. I had to purchase a jack pad adapter in order to lift my BMW 328 coupe without cracking the jack points.
http://www.ecstuning.com/ES251251/
Old 01-09-14, 08:07 PM
Litcroco
Litcroco's Avatar
Thanks for the suggestions guys but I think I'm just gonna make a adapter out of some hockey pucks instead. It's gonna be a good DIY to keep me busy ^ ^.
Old 12-25-21, 07:42 PM
VIS250P
VIS250P's Avatar
I know this is old thread post.. I found out u use 1.5 tons floor jack work.. I went to buy 1.5 tons floor jack and the guy at work told me they arent work for 2.5 tons car... I dont know if it true..
Old 12-26-21, 07:22 PM
Zmon
Zmon's Avatar
1.5 tons is 3000 lbs. 2.5 is 5000 pounds. A 2IS weighs anywhere from 3400-3600 lbs depending on configuration. Peace of mind? Go with a 2.5 ton jack. I wouldn't go with anything less than a 2 ton for a 2IS, IMO anyways. Seems like there's about a $20-30 difference between 2 and 2.5 ton jacks.
Old 12-27-21, 02:03 PM
TimboIS
Liquid Bra Champion
TimboIS's Avatar
You’re not actually lifting the ENTIRE weight of the vehicle. At most you’re lifting 1/4-1/2 the vehicle weight. So 1.5t would be plenty for changing a wheel, etc. But yes for nominal price diff, get something sufficient for future use as well. Low (race jacks) always something to look for.
Quick Reply: Lifting IS 250 with a small floor jack
