IsX50 Cluster & GPS Differences?
Keeping it Real
There are 8 types of navigation system and 2 types of gauge cluster.
2006-2008 navigation systems are the same (Gen 5 DVD-based)
2009 navigation system is basically the same as 06-08, but the bezel is different (newer style)
2010-2012 navigation systems are the same (Gen 6 HDD-based)
2013 navigation system is all on it's lonesome (Gen 7 HDD-based)
For every type listed above there are versions with and without Mark Levinson.
The gauge cluster is the same for 06-10 and different for 11-13 (darker plastic and metallic rings around the gauges like the 08-10 IS F).
Jeff
Jeff
Jeff
Jeff
Thanks!
Huh, thats interesting. So hitting the info button on the steering wheel it never shows MPG? I never knew that was something only NAV cars had lol.
Keeping it Real
All years (06-13) have trip information on the gauge cluster multi-information display. If you cycle through the options using the "DISP" button on the steering wheel fuel information will be right after the outside temperature display.
Outside Temp. > Miles to Empty > MPG Since Reset > MPG Since Tank Refill > Current MPG > Average Speed
Jeff
Jeff
Jeff
Jeff
