Warranty For New IS
I am purchasing a 2010 IS250 with Nav, 51k miles. The dealer where I am buying the car is offering a 4 year 48 for 2600. Question is if I should buy this or not.. Seems high to me.
Also curious what the average issues IS people might have under 100k miles and if it's even needed.
Thanks for the reply.
Just wanted to bump this as I have to make a decision today. I called Jerry and he is telling me that this is a good price for the warranty.
What kind of issues have people had under 100k miles?
I have the same year model with 45k miles but I'm not planning on buying warranty. The only thing I would be worry about is the Nav screen going bad but I heard the earlier models having this problem. not many 2010 and after. Other than that we are covered powering wise till 70k and not much can go bad if follow up with the regular maintenance. Save those money.
Keep in mind that your 50K mile/4 year warranty is up.
Unless they have changed it to 60 months bumper to bumper. Read the warranty on Lexus.com.
Lexus extended warranties are offered to cars within the warranty period. They must be selling you aftermarket warranty. In this case, a lot of research is required.
Good luck.
Good luck.
Basic Warranty
The Basic Warranty coverage is for 48 months or 50,000 miles, whichever occurs first. Wheel alignment and balancing are covered for 12 months or 20,000 miles, whichever occurs first.
Powertrain Warranty
The Powertrain Warranty is for 72 months or 70,000 miles, whichever occurs first. Except for the situations listed on the Basic Warranty page, this warranty covers repairs needed to fix defects in materials or workmanship of any component listed below:
Engine: Cylinder block and head and all internal parts, timing belt and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gaskets
Transmission and Transaxle: Case and all internal parts, torque converter, clutch cover, mounts, engine control computer, seals and gaskets
Front-Wheel-Drive System: Driveshaft, axle, hub, bearings, seals and gaskets
$2600 seems like it's a bit much. That extra $2600 could probably bump you up to a used 350, or at least a lower mileage 250 which would have more factory warranty remaining.
Good luck in your decision.
I have an 07 250AWD, I bought the Lexus extended warranty through Toyota of Greenfield, Mass (thanks, ClubLexus!) for $1480.
So far, the warranty has paid for:
2 door lock actuators ($300 per)
2 rear axle assemblies, the CV boots were leaking (approx. $2100)
2 rear calipers that froze ($800)
Yeah, I got my my value from the warranty, and I still have 5 months left on it.
frankrizzo
RX - 3rd Gen (2010-2015)
23
03-20-16 10:25 PM
