ebay side skirt ings +1 replica fitment issues
so i bought a replica ings +1 side skirt and it doesnt fit!
anyone had the same problems? what did you guys do to make it fit?
im planning to cut some part of it. the ones that you screw
either in front or back
any suggestions?
any suggestions?
buying replicas off of ebay has a high likelihood of going bad. Im assuming its fiberglass, but your best option would be to take it to a auto body shop that has experience working with fiberglass. They would be able to help make it fit better.
not to hijack your thread, you guys prefer fiberglass or poly?
duraflex says theres is a combo of both... i ordered a lip from them, it was broken on each side and cracked all along the bottom even though it had a ton of bubble wrap.
what materials hold up best?
Speaking from experience, polyurethane is the strongest material. ABS is also pretty strong but polyurethane is still stronger. Downside to polyurethane is the paint could chip off from the lip very easily compared to ABS or fiberglass. Stay away from fiberglass since it is the most prone to cracking from any minor impact.
