Got a new spoiler and lip. Which tape to use?
Old 01-14-14, 07:39 PM
smokyis350
smokyis350's Avatar
Default Got a new spoiler and lip. Which tape to use?
Got a Wald spoiler and a Myride diffuser painted. I can't decide which double sided-tape to use.
The 3M VHB (probably strongest tape out there) or the outdoor 5lb tape 3m
I just want to make sure that the spoiler or lip come off.
Old 01-14-14, 07:45 PM
dubUang
dubUang's Avatar
As long as you clean the parts you're going to apply the double sided tape on you shouldn't have to worry about any thing falling off. Also some guys like cutting the double sided tape into smaller sections instead of using a long piece, I think the reason is to have better contact points.
Old 01-14-14, 09:13 PM
Yaboysgs
Yaboysgs's Avatar
Use rubbing alcohol wit 3m 5-10lb double sided tape I'm in New York I get mine from Michaels craft store from picture
Frame section note if using rubbing alcohol once you lay it down its stuck lol I learned the hard way 2nd time was a charm I had 2 15" kicker L7s vibration was crazy and held up no problems with wing..
Old 01-14-14, 09:36 PM
Snyperifle
Snyperifle's Avatar
An autozone near me sells automotive mounting tape that I used for my spoiler. It's stronger than the 10lb double sided tape I've tried in the past
Old 01-15-14, 11:28 AM
smokyis350
smokyis350's Avatar
Picked up a roll of 3m extreme heavy duty tape for 9$ at Lowes. Only 60inches. Ridiculously expensive. Probably need 4 of those to install everything
Old 01-15-14, 11:30 AM
Joeb427
Joeb427's Avatar
This 3M tape is amazing.
You might be able to find a smaller roll locally.
3M VHB Heavy Duty Mounting Tape 5952 Black, 3/4 in x 15 yd 45 mil: Amazon.com: Industrial & Scientific 3M VHB Heavy Duty Mounting Tape 5952 Black, 3/4 in x 15 yd 45 mil: Amazon.com: Industrial & Scientific
Make an even stronger bond with 3M adhesion promoter.
3M 4298 Adhesion Promoter, Sponge Applicator: Amazon.com: Industrial & Scientific 3M 4298 Adhesion Promoter, Sponge Applicator: Amazon.com: Industrial & Scientific
Old 01-15-14, 01:10 PM
metaleckz
metaleckz's Avatar
Lol just buy one at o Reilly it's like $8
Old 01-15-14, 01:25 PM
iLLY
iLLY's Avatar
honestly any of the 3m double side tape would work. i did long strips and when i tried to take it off, it was a bishhhh!!! had to use fishing lines to cut off the tape.
Old 01-15-14, 02:37 PM
metaleckz
metaleckz's Avatar
just as long as you need adhesion promoter
Old 01-15-14, 05:12 PM
whitebeast
whitebeast's Avatar
home depot has 3M TAPE outside use hold up 15lbs
Old 01-15-14, 05:26 PM
smokyis350
smokyis350's Avatar
Yeah, only heard good things about the VHB but jesus christ, $35 for a roll of tape is ridiculous.
Well I picked up the extreme 3m heavy tape rated for 20lb. Gonna give that a shot and see how it goes.
Old 01-15-14, 05:27 PM
smokyis350
smokyis350's Avatar
I heard that heating up the double sided tape until it melts with a heat gun or hair dryer gives it the same affect as the adhesion promoter.
Old 01-15-14, 07:33 PM
smokyis350
smokyis350's Avatar
Installed my rear diffuser. Everything went well except there is a minor gap. What could I do to get rid of this? Some sort of glue?
Attached Thumbnails Got a new spoiler and lip. Which tape to use?-2014-01-15-19.02.01.jpg
Old 01-15-14, 07:39 PM
mnewxcv
mnewxcv's Avatar
3m double sided extreme outdoor stuff from home depot. its super strong, youll need to apply heat if you ever want to take it off. I use it on any temporary mods on my vehicles.
Old 01-15-14, 07:43 PM
whitebeast
whitebeast's Avatar
Did you check fitment before you got it painted? Always test fitment before peel off the tape. I would start from center to both side. Like i post before, home depot has outdoor tape could hold up to 15lbs (black one hold up 20lbs).
Quick Reply: Got a new spoiler and lip. Which tape to use?
