Need help Just had alignment done at the dealer
See below
I was told that SAI is not adjustable and that my SAI on my left wheel is out of spec.
1. If so is one of my control arm bent or any other parts?
2 if somethig is bent the SAI is barely out of spec, is it even worth it to replace any parts or will it have any adverse effects later on?
Cross SAI is completely out of spec, specified range is -.5 to .5 but my cross SAI is 1.1, wll there be any problems??
If you look at the alignment sheet, there are others completely out of spec, im kind of worried. I did hit a small pot hole, I wonder if that caused all this.
[URL=http://s192.photobucket.com/user/gvan1998/media/IMG_20140113_233313_zpsc073fd0b.jpg.html]
[/URL
![](http://i192.photobucket.com/albums/z134/gvan1998/IMG_20140113_233313_zpsc073fd0b.jpg)
SAI is definitely off for stock suspension. Most common causes for SAI being that far off from specific range is bent parts. Does your car pull to the side?
Here is a printout of mine. And I am lowered.
gvan1998
01-16-14 12:39 PM
