IS250 AWD towed...differential damage ??
Long story Short my 250 AWD was towed today to roughly 9km Away (5.6 miles). I did go And get the car back. However after I told my friend about it he asked me if I know how they towed the car (flatbed, dollies, etc.) which I didnt know and never knew to ask.
I'm going to call tmr to ask but for now does this whole "improperly towing awd car will damage center differential" thing apply to the IS250 since it uses an open diff?
When I picked up the car it was facing the wall with rear facing out so worst case they towed the rear with front dragging
Also, my "awd" badge is not on the car from previous damage (failed attempt at plasti dipping) so IF there is any damage can I hold the tow company liable ??
Thanks for any advice
If you drag any car that's in park it can cause damage - you'd notice when driving it. The last tow I had from being in park, they simply put rollers under the back wheels so it wasn't dragging - I think that's pretty standard now.
Keeping it Real
You cannot tow an AWD IS250 with any of the wheels on the ground as it may damage either the transfer (center differential) or the transmission.
It needs to be towed on a flatbed or with dollies under the wheels.
Summary:
AWD models cannot be towed with any wheels on the ground.
RWD models can be towed with the front wheels on the ground.
RWD models with manual transmission can be towed with the rear wheels on the ground, but it's better to tow with the front wheels on the ground, or on a flatbed or with dollies.
RWD models with automatic transmission cannot be towed with the rear wheels on the ground, you have to tow with the front wheels on the ground or on a flatbed or with dollies.
Jeff
Summary:
Jeff
If the company was competent enough to make it the 5 miles and not notice anything breaking. I think you will be fine, if not then you can sue the company for not following proper procedure that lead to damages to your vehicle
They can't just say "It didn't say AWD so we didn't bother doing anything". They know better than the average consumer that damage can occur, so if they aren't going to be better safe than sorry, you better believe they can be responsible. Just saying "I didn't know" isn't good enough when there are simple solutions, like dollies, that they can use to prevent any damage from occurring.
rollers?
Interested to understand how those rollers worked. I might have to tow an AWD 2008 is250 from NYC to ATL. Looking for options...
For the record, placing an automatic in neutral and towing it will burn it up destroying bushings, bearings, clutches, and potentially drum bands. Same is true of AWD center differential/transfercase. They have clutches that are typically only lubricated when the engine is running. As for manual transmissions, many of those can die from being towed too do to the oil splash design isn't the same without the input shaft into the trans being spun.
candyman99
10-13-05 11:39 PM
