In need of some camber?
Old 01-30-14, 10:34 AM
Deegee
Deegee's Avatar
Originally Posted by dannyboy26
Yeah im going to do them myself then have Lexus do an alignment on it
Make sure you do a DIY that'd be kinda nice.
Old 01-30-14, 11:02 AM
dannyboy26
dannyboy26's Avatar
Just did a little research and we actually have a guy here that specializes on stanced cars and is the best in town, so will only be looking at $70 for alignment after I put them on
Old 01-30-14, 11:03 AM
dannyboy26
dannyboy26's Avatar
Yes I was going to since there's not one yet
Old 02-19-14, 04:52 AM
Sfrt
Sfrt's Avatar
jgr7 and dannyboy26, Curious if you've put the front and/or rears in as yet? Want to do mine in the spring so would love to see a DIY on this.
Originally Posted by jgr7
I didn't even need the the ball joint seperator, just loosen the nut till it is even with the stud and give the end of the stud a wack with a hammer. I reused the nut from the stock arm as it has a better built in washer. Adjust the new arm to the same length as the old arm and then make it a little shorter to start with then go from there. Make sure you loosen both lock nuts and unscrew both ends the same before you install. The inside is left hand threads so after it is installed you loosen the jam nuts and turn the center of the arm to shorten or lengthen then tighten the jam nuts to secure the length. It is very easy.
Old 02-19-14, 06:41 AM
dannyboy26
dannyboy26's Avatar
Have not done mine yet, found where I was rubbing and just did some more fender modding and now domt rub at current height, but after my trip in April will be doing them just to go a little lower
Old 02-19-14, 08:47 AM
Deegee
Deegee's Avatar
Actually installed my rear arms this weekend, pretty easy, don't think a DIY is even necessary.
Old 02-19-14, 08:50 AM
dannyboy26
dannyboy26's Avatar
Whats your camber set at now?
HellaInc
01-10-14 04:49 PM
ozzy250
Suspension and Brakes
04-19-13 12:42 PM
Lanceezy
12-02-12 11:26 PM
bacon22
IS - 1st Gen (2001-2005)
20
05-29-12 04:02 AM
671IS250
06-13-11 10:28 PM
Quick Reply: In need of some camber?
