Headlight stopped working
Old 02-12-14, 08:56 AM
Armymedic
Armymedic's Avatar
Default Headlight stopped working
I am new to this forum and I just bought my wife a 09 IS250 with OEM HIDs. I have had a lot of moisture in the passenger headlight since I got it (2 weeks ago). The other day I took the DRL bulb out and tried to use a blow dryer to dry it up. That night the headlight went off then turned back on about 15 minutes later. The next day same thing. Now I can't get it to come back on at all. This weekend I will switch the known good bulb to the passenger side to rule that out but any suggestions?
Old 02-12-14, 11:15 AM
Armymedic
Armymedic's Avatar
anybody have any input?
Old 02-12-14, 12:49 PM
Serifiyah
Serifiyah's Avatar
Heres some threads I found that might help you the moisture.
https://www.clublexus.com/forums/is-...ts-normal.html
https://www.clublexus.com/forums/is-...ed-advice.html
Old 02-12-14, 06:15 PM
Armymedic
Armymedic's Avatar
Thanks for the reply, yeah I saw those threads but nobody has really said yes the moisture in the headlight can cause a blown bulb or ballast
Old 02-12-14, 07:43 PM
jdmSW20
jdmSW20's Avatar
just try what you originally said you were going to do, swap the bulbs to see if the issue is the bulb itself or the ballast. the cause is relative at this point. in my own personal experience it was my hid bulbs that were bad. i swapped those out for good xenon depot ones and havent had an issue ever again
Old 02-12-14, 08:13 PM
my1s250
my1s250's Avatar
check to see if the moister cap is on the right way find those little bag of silica in shoe box or wherever and throw it inside the headlight to suck out the moister or else your headlight will turn yellow
Old 02-13-14, 03:07 AM
Armymedic
Armymedic's Avatar
Thanks for the replies I will just have to wait until this weekend to diagnosis it. Where is the moisture cap though?
Old 02-14-14, 11:49 AM
Armymedic
Armymedic's Avatar
So I switched the bulbs today and figured out that's not the problem so I guess I am ordering a ballast tonight. I saw the tutorial on how to remove the silver shield from the plugs and pull the wires out but when I take the headlight out where is the actual ballast located?
Old 02-14-14, 12:00 PM
Armymedic
Armymedic's Avatar
Actually I just searched and found out its underneath the headlight. Luckily I have off next week so looks like that's what I will be doing. Hopefully I can get rid of this moisture as well. Does anyone have a link to that video of how to remove the ballast without taking apart the headlight because I can't find it anymore.
Old 02-14-14, 12:04 PM
Jump2man3
Jump2man3's Avatar
not sure but if you check out youtube or in the search put in oem ballast removal and something may pop up. Or you could just upgrade to hids
Old 02-14-14, 12:24 PM
Armymedic
Armymedic's Avatar
Yeah I'll try that. I have HIDs
Old 02-18-14, 06:39 AM
Armymedic
Armymedic's Avatar
I should get my new ballast in Friday, I can't wait I hate driving around with one headlight. I looked last night and realized my parking light is out as well. I know this is any controlled by the ballast so I just find it strange and hope it is in fact the ballast.
Old 02-18-14, 12:33 PM
nabbun
nabbun's Avatar
Good luck, medic. And welcome to the forum.
Old 02-20-14, 05:24 PM
Armymedic
Armymedic's Avatar
Well I replaced the ballast today and thankfully it worked. All in all it wasn't to bad to replace it.
Old 02-20-14, 05:25 PM
Armymedic
Armymedic's Avatar
Nabbun you still an 11B?
BCT
06-29-18 08:53 AM
sallydrive
05-30-13 09:53 AM
RXSF
07-01-08 07:35 AM
qman2002
06-15-08 02:05 AM
Quick Reply: Headlight stopped working
