Rear window auto sunshade help
I have the switch and the rear window auto sunshade but need help in the switch connection and in the sunshade. I look under the front dash and did not fine the plug , do I have to run some wires. If any one has done this and can help me out I will appreciate.
Hi PAVGR
I check in front under the dash but no lock. I found a blue plug that goes in the headlight washer switch it did not fit in the sunshade switch. I have not check in the back yet I am trying to fine the plug for the sunshade switch but probably my car didn't come pre-wired for this option. I need to identified witch are the power , up/down, ground, pins in the sunshade plug. Do you know this?
That's for your help man
