2011 IS250 Hesistation after oil change
So I just change my oil at 20,000 miles. I went from mobile 1 0W20 to royal purple 0W20. Car ran great on mobile 1 but I decided to change it to royal purple because I heard it was better. After oil change I notice the car feels a little sluggish and sometimes feels a little hesitation when its shifting gears. It is an automatic with a K&N intake. it took about 75 miles after I reset the maintenance light for it to get use to the intake again because it was running really bad. it does feel a lot better now but I can still feel some hesitations and sluggishness. any idea what could be wrong?
I also change the cabin filter and the intake filter and I used about 6.5 quarts of oil with a Toyota oem filter. Thanks
no I dident. all I did was change the oil. I am not sure if royal purple is just not good in that engine. but I find it very strange and cant find a reason for it yet. I think I will drain it and put back mobile 1 and see if it goes back to normal. unless you guys have any ideas. thanks
would resetting the oil light reset any sensors or anything like that which would give me this problem?
I would say no. Additionally, the change in brands of oil would not cause the problem you describe. What you describe as sluggish with a hesitation sounds to me like the air/fuel ratio is on the lean side. This points directly at your K&N intake modification as the culprit. Anytime you jack with the stock intake or exhaust, you're asking modern cars to compensate for something that the engineers didn't design. Put the stock intake back on and your car will be quieter, smoother running, and more than likely faster.
ok so I disconnected the battery and let it sit for like 30 mins then I reconnected it now it runs perfect. the ecu is still learn but no more hesistation or feeling sluggish, thanks a lot for the help everyone, my name is Anthony btw and I have not had the chance to introduce my self to club lexus as yet but nows a good time. I own a 2011 IS250 Matador Mica Red.
This was a pretty interesting read as I am also looking into intakes. Thanks for the info and I am glad to hear that your issue was fixed.
Is there any downside to resetting the ECU?
Thanks
Thanks
mikeho
12-18-07 08:34 PM
