Streaming Audio via BT - Stock '12
Hey All,
I have a 2012 IS250 with Nav. I know you can stream audio via bluetooth but when i connect my phone the bluetooth "button" on the nav screen remains grayed out. Is there an additional step i need to do in order to connect for audio?
I am sure it says something somewhere in the owners manual but I am lazy and want answers by the time I leave work
Press "set up" button and connect your phone to bluetooth (what you already did) and then inside "set up", you will also see "audio" or "bluetooth" i forgot and play around with that and add your phone as a player. I believe you can add only 2 phones max for audio streaming. Anyways, play around with the "set up".
Is the sound quality just as good as using the AUX jack?
