Volk wheels on IS
Old 03-21-14, 05:42 PM
crazy8ship
crazy8ship's Avatar
Default Volk wheels on IS
I have a set of Volk GT7 wheels that I had on my G35. I didn't think they would fit the IS but after seeing someone on here put a set of 370Z wheels on an IS I am wondering if they would now. Does anyone know? They are 19x9 and 19x10 I think. I have a IS250.
Old 03-21-14, 05:45 PM
laobo979
laobo979's Avatar
Should be the same bolt pattern 5x114.3 but you might need hub ring to fit. Depends also if your RWD or awd? Tire size for fitments and offset.
Old 03-25-14, 09:26 AM
crazy8ship
crazy8ship's Avatar
Great thanks. I have staggered wheels but they are only an inch difference to I am going to give it a try. I will have to get some TPMS ordered though since my G35 didn't have them.
Old 03-25-14, 10:25 AM
iRyan
iRyan's Avatar
should work...maybe be a tad aggressive so look out for fender touches, so you may have to roll the fronts and shave the rears
Old 03-25-14, 11:32 AM
azfsprt
azfsprt's Avatar
Ya what he said.. Roll fenders and or tires low profile. So depends on your offset too.
Old 03-26-14, 07:24 AM
SubieChik
SubieChik's Avatar
Offset would definitely help....you don't know it?
Old 03-26-14, 08:29 AM
crazy8ship
crazy8ship's Avatar
I just found the old thread from the guy I bought them from on g35driver and they are:
19 x 8.5 +23 on 245/35
19 x 9.5 +24 on 275/30
Where is the best place to get TPMS? Used ones on ebay?
Old 03-26-14, 09:00 AM
freal
freal's Avatar
i used to have a set of GT7's on my IS350 the specs were a tad off from what i wanted so i ended up selling.
-19x8.5 +42 front and back.
-Front tires-225/40ZR19
-Back tires-245/40ZR19
i had to use a spacer to clear the brakes and the front rubbed while turning.
also i was on stock suspension bumps in the road caused rubbing as well.
Old 03-26-14, 11:49 AM
crazy8ship
crazy8ship's Avatar
The lower offset will give me more clearance correct or will I be rubbing with these? I am not lowered right now but might in the future.
Old 03-26-14, 12:10 PM
laobo979
laobo979's Avatar
I think tires size is over kill for IS. Take the 245/35 to the rear and get 225/35 front. But you can test fit to see if the size works for you.
Old 03-26-14, 12:41 PM
freal
freal's Avatar
The lower offset will give me more clearance correct?
Someone who knows correct me if I'm wrong, but I don't believe that because you have a more aggressive offset than I did that you will be able to clear your brakes. Only because offset is basically pushing or pulling the barrel of the wheel in or out, not having anything to do with how close the spokes are to the brake system.
Old 03-26-14, 12:53 PM
crazy8ship
crazy8ship's Avatar
Well they cleared my brakes on my G and I am sure the brakes were much larger than the ones on the IS250. I am more concerned about rubbing though. I wouldn't go out and buy rims with these specs for the IS but since I already have them I thought they would be worth a shot. If not I will sell them on g35driver but it will probably be hard to let the wife let me turn around and get another set.
Old 03-27-14, 05:27 AM
freal
freal's Avatar
you can try to put them on and see what happens. Worst case you can go to Autozone or Advanced Auto Parts and get a 5/16th spacer. that was enough for me. good luck and keep us posted!
Old 03-27-14, 05:36 AM
SubieChik
SubieChik's Avatar
The lower the offset the greater chance of rubbing. Basically the lower you go the closer to the fender your wheel will sit.
Old 03-27-14, 05:48 AM
SubieChik
SubieChik's Avatar
Here's an example....top pic is +35 offset....bottom is +22. I know I was lower in the second pic and I have way smaller tires lol, but I had to do a hit to make that offset fit.
Different view
Quick Reply: Volk wheels on IS
