SAT radio option for XM install
I've been wanting to get XM radio installed in my car. my 2006 IS350 has the option for SAT. i've contacted Lexus and they discontinued that part which means i have to go elsewhere and find the "right" part..
Anybody else looking to install XM in there car? and possibly know where to get the parts?
Parts are available. You have to buy them separate rather than getting the install kit. I just got a harness and bracket from Toyota/Lexus. The tuner I got off ebay so save $$ & I just recently discovered, since I have an 06, that I need the antenna so thats on order as well.
Harness is PT54653060CK
Bracket is PT54653060BK
Antenna is PT54653060AK
I got mine from oemlexusparts.com
The harness also came with cushion tape & zip ties, while the bracket came with screws, and a ground cable. I decided to buy an install kit for a Lexus LX570 off ebay for the antenna. It comes with a longer antenna giving me options of where I want to mount it.
Here is the link to that: http://www.ebay.com/itm/140933263182...84.m1423.l2649
So after doing some research/calling around, If you have the shark fin already installed that is your antenna. You need to install the tuner/harness and connect it to the shark fin antenna wires, But that's only for the IS owners who have the shark fin, And if you don't have that then you have to install like a receiver type of part in the trunk OR in the back of the car by the windshield
Understand this to be an older posting however, interested in knowing if the satellite tuner was installed by Lexus when vehicle was purchased, would it be mounted differently in a different location with different mounting bracket, than if the 86100-0W220 Mounting Kit was used, or is the same kit used by Lexus as well?
Sure
Edit - I guess XM came on 2010 as ready equipped right? Some some dealership page said the harness was only good through 2008, maybe they had their years off
