Will Infiniti M35 "19 wheels fit on lowered 350?
Just looked up the specs on the M35 wheels, 19x8.5 should be fine, it should clear the BBK in the front if not 5mm spacer will do the trick, im running a 17" face on a 18" step-up lip and i need a 5mm space to clear the front, as far as the rear, the rear should be fine, i had 19x9.5 in the rears wheels on stock body, now im running a 18x11.5 -7 with modified quarter panels.
Whats the spec on the wheels? You can see the big wheel and tire thread and compare from there when you get those specs. I haven't heard of anyone here with m35 wheels yet just thw g35, g37 or 370 so search around. It might be the same specs since its all nissan
i'd recommend 235/35 19 fronts, and 255/35/19 rears i was rubbing with 40's but again i was on coilovers, didn't feel like adjusting the height to achieve no rub, i eventually switched to 18's because of cost difference of 19" tires and most tire company in my area usually never carried them in stock if something would've happened.
