Sewell led headlights
Hey guys
im purchasing the loaded led upgrade set from sewell HID headlight with LED DRL
question for the gurus
does anyone have a diagram so the headlights function as if they where installed at the factory......
(just put them on auto and go)
i have a 2010 is 250 with halogens
thanks for your help guys
Oh nevermind, I think you mean the HID headlight with LED DRL. There is a tutorial here that should be helpful to you.
https://www.clublexus.com/forums/is-...on-how-to.html
you should only need to cut the bracket on the back in a U shape for the headlight to fit on the bracket, that's it
Not sure if you would need to change your flasher since you have an 2010 sorry I don't have a link but in the DIY section search 2012 headlight and there is a diagram on there hope it helps
