Help install passenger window
Hey guy !
I need help on installing a rear passenger side window. Someone decided to broke Into my car. I have open the door panel... But don't know why is not going into place.. Anyone have some tip on how to install the glass in ?
Thank in advance guy...
Pretty much, all I need is how to slide the glass window in between the panel for install but when I try to run it down thru.. Dosent go all the way down. Do I need to remove anything beside the door panel. When you sayed removed the window run. Do you mean the regulator which run up and down ? Or the black window run next to smal glass panel
Thank in advance for helping a beginner out
I am refering to part # 68142C/68152C. I also like to remove this (part # 67407E/67408E to get more wiggly space. Held in by a philips bolt on top and 2 10MM bolts . No need to remove the quarter glass.
I personally never did a rear glass on a 2IS before, but i've done plenty of camrys, avalon, and Lexus like vehicles. It should be all the same.
Thanks man... I did remove the part 67407... And bam problem save !
