2006 IS350 engine noise, vid attached
Wondering if anyone can tell me if this noise is normal during idle. I dont recall hearing it this loud before. Not the ticking noise (fuel injectors) but that other truckish noise in the backround. Thanks in advance.
https://www.youtube.com/watch?v=y9eP...ature=youtu.be
Seems pretty normal to me. I don't know why but almost every IS 2 gen does this. Depending on how many miles you have on your car you may need to replace your belts which are like $50.
FYI: We don't have a timing belts we have timing chains and you don't need to replace those.
I've been hearing this exact noise since the start of December. I only started noticing after the recall and thought it might also just be down to the cold winter weather. It goes away after warm up (5-10 minutes) but I'd still like to know if it's something to be concerned about.
skydash
05-16-17 09:06 PM
