Engine Oil -5W30, 0W30 or 0W20
Old 08-01-14, 06:31 PM
Mike_1GO
Mike_1GO's Avatar
royal purple HPS 5w30
Old 08-02-14, 07:45 AM
JohnLX300
JohnLX300's Avatar
Default M1 0W30 Oil Analysis
I attached my Mobil 1 0w30 oil analysis that I just did on my previous oil change.
Just some material for those who would like to view it.
File Type: pdf
Old 08-02-14, 09:49 PM
robtwo
robtwo's Avatar
I would tell you RP is only slightly better then M1.
Old 08-03-14, 05:28 AM
Mike_1GO
Mike_1GO's Avatar
im not sure what oil the previous owner had but when I switched to RP about 600 miles after I purchased the car, I did notice the engine ran much smoother. a lot of other members running RP say the same. And RP does have a certification for their regular synthetic oil but no certification for HPS. RP says their HPS oil provides one of the best cold start protection. plus it contains high levels of zinc and phosphorous. I saw the ball bearing test vid and I was sold.
Old 08-03-14, 08:19 AM
darkdream
darkdream's Avatar
Originally Posted by FSportIS
What is M1? Any back up of it being junk? (not provoking an argument, merely curiously asking questions)
Also, if a person drive the car hard (autocross once a month, occasional track etc), can they stick to the 10k interval oil change with synthetic oil per Lexus recommendation? if not, what should the interval be?
Definitely not! All things need to be changed more often. That includes brake fluid (But I assume you use a racing fluid if you take it to a track and do that anyways).
Old 08-03-14, 08:25 AM
robtwo
robtwo's Avatar
The oil breaks down in heat. Go read the results of running M1 in any spirited fashion.
I ran M1 EP for 140k on 15k intervals without consumption. However that was light commuting. I chewed through a chain tensioner with it on another car. On a turbo'd car it is water very quicky.
Not all M1 is bad. See prior comments.
For the money there are better. Castrol is great for the coin.
If you're going to push the car, best to test the oil or for safety just half the interval. Instead of 10k go 5k. I am a firm believer in testing to confirm.
Old 08-03-14, 08:30 AM
robtwo
robtwo's Avatar
I have seen the same video. You should test the oil. I have seen some bad results from RP when pushed.
In my opinion, for the money, redline or amsoil provide a lot more protection. They are also the top two oils available for sale in this country. Both out perform the competition on all metrics. Amsoil #1 and redline #2. Both are packed with additives and don't sheer down too easily.
Both would be "over kill" for commuting mind you.
As for your improvement might only be the switch to a syn.
neomedic
10-16-16 10:17 AM
mkhaira
08-15-11 08:09 AM
leokcm
08-09-08 05:49 PM
MikeIS
Maintenance
15
12-27-05 12:17 PM
mofogasm
12-16-05 11:41 AM
Quick Reply: Engine Oil -5W30, 0W30 or 0W20
