Transmission cooler
Going to necro this post but I'm looking for a solution. I see just two options, adapter plates meant for flushes from the g-tec store to detour trans fluid to a typical external cooler (and bypass the coolant lines) OR re-route the OEM coolant feed line to a cooler then back to the tranny so that at least the coolant is cooler before then cooling the trans. Any progress on the trans cooling front for the ISx50?
My previous posts were as far as I came to a possible solution.
Ultimately I decided to sell the IS350 and buy a 2010 ISF ... whilst it was a solution of sorts, it certainly wasn’t the most cost effective!
Since changing to an ISF I have never lost any time out on track having to cool down the transmission, which was a big plus for me. This has resulted in at least twice the number of hot laps per session!
The other notable difference is just how much longer the brake rotors last on the ISF. The fronts last twice as long, but given I also get more than double the number of hot laps per session, in reality they are lasting four times as long. The front track brake pads (Project Mu RC09’s) last the same time ... generally 4 track days, but again I am getting twice the distance out of them due to more than double the number of hot laps. The rear rotors I have yet to change and the same Project MU RC09 track pads last double the number of track days, but again with more than double the number of hot laps that really equates to four times the distance.
Anyway good luck with exploring your options!
They seem to be two good options to consider.
I think I will explore routing the coolant lines to a cooler rated for radiator fluid. Heater cores would be perfect and cheap, but bulky.
Rather than add a 2nd radiator (which is what you would be doing by adding an inline "transmission" cooler) why not just a radiator with more cooling capacity? That way both the engine and transmission can take advantage of more cooling capacity. http://www.koyoradracing.com/product...asp?make=Lexus
IS-F upgrade aside, (nice!!!)....
A word of warning, do not direct connect your trans to an external cooler. It will increase the wear while not at operating temperature. Because of this it will also build up and retain more moisture (depending on use and environment) until it hits and retains operating temp ~177 to 200F. Old days before lock up torque converters the converter always slipped so there was plenty heat from slipping before and after reaching stall speed. These days not so much. FWIW I used rebuild these things so I have some experience here. Not just making **** up... lol
The parts list above is only missing the right angle fittings that screws into the trans. That aside that truck cooler is way over kill for most of us unless you track your vehicle or place the cooler somewhere with little air flow.. There are plenty of cooler options available just make sure it is for transmission. If I were to do this I would route steel lines forward vs running hose. Just make sure all hose fittings are barbed or you risk blow off under load.
Also keep in mind you will need some good quality fittings for the return path on your engine coolant. Try to avoid plastic as the exhaust heat will take its toll on it.
If you do install an external cooler you can install a thermostat like this: https://www.amazon.com/dp/B004XONNRQ/ inline so you can get proper warm up.
When I first looked into this I could have sworn I found Toyota truck part (tow package only) that did both heating and diversion that fit the A760 trans. The PN above is a 2 year only that can also be found on the SR5 addition and Sequoia of 06 07. That said I think the other is out there, we just have to find it.
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/20190524_183513_e746de9b2eb2186169330b052b6e7b877ad4c6fc.jpg)
redspencer (06-12-19)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/1413x738/smartselect_20190612_124427_gallery_8d1682b818db5c016ef4d634b5ef3a1ddb32d8ec.jpg)
After reading your post, I added the A/T oil temp reading display to the my dashboard and it appears to vary temp degrees by a decent amount to consider it reading from a different sensor source (bottom left is my A/T oil temp display in comparison to the other two coolant displays).
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/1400x1599/smartselect_20190612_124450_gallery_2e2a46728203b59c7e973469d85d5a3204286fb5.jpg)
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/1403x1582/smartselect_20190612_124503_gallery_4d75939f8e965909b8c73f13f377666e58a2f7e3.jpg)
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/1389x1582/smartselect_20190612_124517_gallery_99b4fc11d4d5e435d9df04cf8f46ccc815107c40.jpg)
In general, watch it during start up. Coolant will hit 185F well before the trans.
Then if you feel like raising the trans temp, power brake it (in gear, stopped, brakes applied, throttle applied) even 60 seconds at 1800rpm will jack up the trans temp.
Thanks for post Red. Do you have the Toyata pack add on?
As stated, Torque P simply mirrors coolant. So that's not helpful.
Wow so many good replies, thanks all!
Yeah for sure do not want to over cool, this was a concern of mine when putting in a giant Hayden on my truck, but I put it in series with the radiator trans core so it wouldn't get out of hand.
I'm not confident an upgraded radiator would make a good effect as I imagine the puck gets coolant from the thermostatically controlled portion of coolant. I think if anything going to a cooler thermostat would be more effective but I'd like to keep OEM engine temps for desired efficiency.
X2 my torque app is simply listing the coolant sensor output as trans temp, there should be a pid that can fix this...
Google pics of heater cores, lots of affordable thin cores out there. Unfortunately one does not have a choice to run it pre or post OEM radiator like typically cooled trans, it will have to be post output and could possibly over cool at times. I'm going to look into those amazon thermostats.
I'm agreeing there must be some OEM parts out there that allows an external cooler to be integrated with all of the other applications that use this trans family...
I did another cold start observation this afternoon and verified that the engine coolant temp reading reached operational temperature several minutes before the A/T oil temp display did which indicates that the app is indeed displaying the transmission temperature.
Start-up
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/1404x1592/smartselect_20190612_202307_gallery_44a2f931a7bf7a0b889cdd0b75e20f56fc0711d1.jpg)
Near operating temperatures
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/1396x1616/smartselect_20190612_202340_gallery_97d469b32ff9e7a72273fb032fd11c2029cfb78e.jpg)
Operating temperatures
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/1403x1611/smartselect_20190612_202350_gallery_62701c6fea570961238d7f17c5d92196258bc62d.jpg)
The part above recirculates oil to the trans until it needs cooled. That said I think one exists that heats and bypasses for cooling. And this is just me but I'll take a new oem over ebay part on something like this. Maybe add an electronic gauge to the cabin too. But I don't track her so less of a need.
At post 23, a screen shot shows instrument displays on a navigation screen. Does anyone know how to make that happen?
